EK DX Front hubs on EF Si...
Old Aug 28, 2007 | 06:04 PM
EFstyle's Avatar
Default EK DX Front hubs on EF Si...
would this be posible?
Old Aug 28, 2007 | 07:13 PM
EFstyle's Avatar
Default Re: EK DX Front hubs on EF Si... (EFstyle)
Old Aug 29, 2007 | 11:08 AM
EFstyle's Avatar
honestly nobody knows??
Old Aug 29, 2007 | 11:09 AM
89s1's Avatar
Default Re: (EFstyle)
try and let us know... doesnt sound like something that ppl do everyday
Old Aug 29, 2007 | 11:14 AM
24TEN's Avatar
PHANTOM MENACE
haven't done it or seen it myself but i'm pretty sure it'll work. camber might be off as a result. question, why are you doing this?
Old Aug 29, 2007 | 11:25 AM
peanut butter's Avatar
Default Re: (24TEN)
I can tell you that eg front hubs don't work on ef's because of different geometry so I would assume that the ek suspension geometry is a little different too. Unless you compare side by side you won't really know.
24TEN's Avatar
PHANTOM MENACE
Default Re: (peanut butter)
don't work? or don't work properly?
Old Aug 29, 2007 | 12:34 PM
Default Re: (24TEN)
Well in actuality I never mounted it up on my car but putting them side by side the upper control arm mount for the ball joint was at a different angle and position, the knuckle I can't remember exactly what was different to be honest.
It was enough for me to just buy the new control arms and ball joints for my crx knuckle and replace them rather than swapping hubs. So, try it at your own discretion.
Old Aug 29, 2007 | 09:32 PM
EFstyle's Avatar
well heres the deal... i have my 91 Si and the wheel bearing and ball joints are gone... i also have a 99 dx hatch sittin around that i recently totaled... i already took the trailing arms off of the ek and put them on the Si because of the better conditon the bushings where in and the bigger drum brakes... anyways insted of paying o get 2 new wheel bearings pressed in and all new ball joints... i was going to see if i could just swap those off of the ek as well... but from what I read... looks like the angles and such are going to be off... guess im better off picking up the sir front hubs i was offered...
Old Aug 29, 2007 | 11:38 PM
EFM_ookie's Avatar
i know ppl who have used 00 si front knuckles. They work but are not the "correct" or perfect geometry for the car. 88-91 ex knuckes are the best bet for our cars but are really rare to find.
Old Aug 30, 2007 | 01:25 AM
H22_aCCoRd_07's Avatar
Default Re: (EFM_ookie)
yeah what he said^^^^^^^^^^^^^^
Old Aug 30, 2007 | 08:02 AM
EFstyle's Avatar
Default Re: (H22_aCCoRd_07)
so if i did use the ek ones.... what exactily would be off??
Old Aug 30, 2007 | 08:18 AM
akandok's Avatar
I dont know about all this angle crap. Last night I installed GS-R front spindles on my 88 crx si. Used stock control arms and everything fit fine. Drives no problem. I changed my outer tie rod ends so I need alignment but its fine.
So to answer your question, just swap them in. Worst case scenario get alignment..
Old Aug 31, 2007 | 01:42 PM
EFstyle's Avatar
Default Re: (akandok)
well the ek hubs are in and they seem to be fine... just need to get an allignment for sure...
Old Aug 31, 2007 | 02:20 PM
EFM_ookie's Avatar
deff get an align after you swap it out
Old Aug 31, 2007 | 02:25 PM
EFstyle's Avatar
yeah seems like if anything... my wheels are pointed a bit out now....
Old Aug 31, 2007 | 06:50 PM
dem0nk1d's Avatar
well i would like to see the specs on 92+ spindles
Old Aug 31, 2007 | 08:37 PM
89s1's Avatar
Default Re: (dem0nk1d)
man, without the drag of those crumby old wheelbearings you might as well have just installed a cai, the cars gotta be faster now
Old Aug 31, 2007 | 08:44 PM
EFstyle's Avatar
Default Re: (89s1)
idk yet i havnt even drivin it... just finishing my swap... im pretty excited to see how quick she is
SVOboy
11
Aug 14, 2006 06:28 PM
slammedcivicsi
Dec 20, 2005 05:08 PM
FS_WTB
Mar 13, 2005 05:57 AM
tnd2gen
11
Oct 10, 2003 03:43 AM
paulzy
Apr 12, 2003 01:23 AM
