b16 clutch in teg?
Old Jun 14, 2002 | 09:18 AM
legendboy's Avatar
Default b16 clutch in teg?
If I have the b16 flywheel and clutch assembly, it work in my ls teg? any disadvantage to it?
Old Jun 14, 2002 | 10:23 AM
Rocket's Avatar
Default Re: b16 clutch in teg? (legendboy)
B16 Clutches are the same as LS clutches (usually PR4). These pressure plates usually have about 1300-1400lbs pedal pressure.
The GSR pressure plates (P72) are the best from the factory and come in at 1700-1800lbs pedal pressure.
