dirty headlights
i went to clean my headlight lenses cuz they're so dirty... and only one side too... the other side is crystal clear for some reason. anyways it turns out its dirty on the inside... is it possoble to get in there?? do i have to take off the bumper?
Modified by 98tegfreak at 6:37 PM 8/28/2007
oh ok thx that explains more... but that would require me to buy another something... thx for the tip but if its possible i'd like to take off the lense
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fliplm0de »</TD></TR><TR><TD CLASS="quote">put your headlights in the oven and remove the housing then clean it off
search diy black housings and you should see instructions on how to remove the housings</TD></TR></TABLE>
in the oven?? thx for the search but it came up with nothing
yea melt the glue that holds the lense to the housing then clean the lense and make sure you get a goood seal putting them back together or you will gather moisture...cool tip for tailights if you have clear lenses and you melt the housing apart and paint the house the color of your car or any color you like really but leave holes for the lights it looks pretty sick....
why don't you try something instead of being lazy! get off your azz and do something! they are not going to fix themselves they gave you a site and the knowledge put it to work! if you can't even take off a bumper than maybe you should forget it altogether.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-TRBO-DA »</TD></TR><TR><TD CLASS="quote">why don't you try something instead of being lazy! get off your azz and do something! they are not going to fix themselves they gave you a site and the knowledge put it to work! if you can't even take off a bumper than maybe you should forget it altogether.</TD></TR></TABLE>
i never said i couldnt. i said do i have to? cuz i dont wanna take it off if i really dont have to, and i really dont feel like taking off random bolts until the headlights come out either.
you have to "bake" your headlight. Kinda like retrofitting. http://www.hidplanet.com go on forum section. you bake your headlight in the oven. Preheat to 400, then turn off and put headlight in. the rubber with become soft enough that you can pry the 2 peices apart. and BAng you can clean. then you need to reseal with some rubber cement stuff. look it up. pretty detailed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mfoehrkolb »</TD></TR><TR><TD CLASS="quote">and for you taking them out of your car... really just look. it isnt rocket science if you spend a couple minutes actually analysing the situation.</TD></TR></TABLE>
yea i just got done with that... took off the bumper and the lights... i just gotta figure out that oven thing... i heard someone say somethin bout foil... is that really necessary??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-TRBO-DA »</TD></TR><TR><TD CLASS="quote">why don't you try something instead of being lazy! get off your azz and do something! they are not going to fix themselves they gave you a site and the knowledge put it to work! if you can't even take off a bumper than maybe you should forget it altogether.</TD></TR></TABLE>Good job on being a smart ***! If you didn't have anything helpful to say then you should shut your face!
APEX i GSR
Feb 6, 2004 03:13 PM
