96 acura rl wont start
Sup HT I got this 96 acura rl the shop just put in a motor and it's not starting,it's getting fuel but no spark at all.I had to buy another ecu because when I would turn the key the check engine light wouldn't even turn on,when I swapped the ecu and turn the key check engine light turned on then off which means the main fuel relay is fine correct?I also changed the coils,Im now thinknig it could be the cam angle sensor. what do you guys think let me know thank you very much.
If you swapped out the ecu, you will need to have it programmed at a dealership to work with the immobilizer system. Otherwise the car will turn over but never start.
Chriseh9
Dec 10, 2018 06:49 PM
Bill Cantrell
Jul 15, 2017 09:21 PM
toytroy
Sep 27, 2012 10:06 AM
whitecrx
Jul 9, 2007 03:11 PM
