new axles throw off alignment?
I just had my axles replaced at a shop and now it seems that my car pulls, as if its not aligned right anymore. Is it possible my alignment is off or something else might be wrong? I did check tire pressures and they were all the same.
yes it can throw your alignment off. think of it as any difference between the old axles and new ones will throw alignment off.
Best rule of thumb is to get the car aligned whenever you do any suspension work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord2nrz »</TD></TR><TR><TD CLASS="quote">Best rule of thumb is to get the car aligned whenever you do any suspension work.</TD></TR></TABLE>
Ditto. Since the shop had to remove the steering knuckle out of the way, they could have accidently changed the adjustments. So get a wheel alignment.
meh, i need new tires, i'll just get one when i get new tires i guess. I would think they'd put it back to spec. Idk, haven't really inspected it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arielb1 »</TD></TR><TR><TD CLASS="quote">nope, new tires will not put back to spec...do yourself good and get aligned when you put on new tires.</TD></TR></TABLE>
huh? i said i'd get one when i get new tires..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 »</TD></TR><TR><TD CLASS="quote">I just had my axles replaced at a shop and now it seems that my car pulls, as if its not aligned right anymore. Is it possible my alignment is off or something else might be wrong? I did check tire pressures and they were all the same.</TD></TR></TABLE>The knuckles have to be removed - or at least swing out of the way to remove the axle. The easiest way to do that is separate the balljoints at the tapered studs. In that case you won't need an alignment.
But... If they took it apart a different way, they may have thrown something off.
sting94112
Feb 3, 2004 04:09 AM
AMChev
Apr 4, 2002 01:11 PM
