Strobe Lights
I just installed my strobe lights for the inside of the car near the floor boards. I spliced the wires to the same power and ground. They work but the passenger side light is flashing at a slower rate than the driver side. Any clues on why that is?
Please to check yuo 2MHz oscillator. It to control yuo curent fluctuation and to light up yuo strobe. If 2MHz oscillator setting to is optimal, please to check yuo variable velocity transmitter at the control source. If **** is inaccurate to setting, strobe to flash at different time.
Alginates, derived from the cell walls of brown algae, are used in beer, frozen desserts, pickles, adhesives, boiler compounds, ceramics, explosives, paper and toys.
Accord Ricer.
Accord Ricer.
but seriously though, since you've got them running off the same power source, the first one in line is pulling too much for the second unit to "hit" at the same rate.
the same as if you had about six amplifiers and tried to run them off of the same remote wire. it wont deliver.
[Modified by carolinaACCLUDE, 3:00 PM 6/14/2002]
[Modified by carolinaACCLUDE, 3:04 PM 6/14/2002]
you spliced the wires, effectivly running them in series, hence not getting enough power to the second one in the series.
Run a seperate power to each, they should be able to use a common ground. Then you will be a stunnin fool yO!
Granted, most people hate strobe lights, alteezas, etc. I agree with you on the alteezas, but I like my strobes. Just like you may want to do something to your car that everyone else in the world may hate. It's not what looks best to everyone else...it's what looks best to you in your car.
