909 Garage Sale *** Back by Popular Demand ***
Ok, a little bit about this car. It was once an AEM/ DC Sports project car given by American Honda... you might remember the Maroon DC Sports RSX Type S? Anyways, AEM was finished w/ the car and Honda asked for it back. A friend of mine wrote a proposal to American Honda asking if he could keep it and they accepted. Honda sold the car to him for a buck! It could not be used on the street... so he re-built it all and wanted to compete in some of the Honda Challenge Races... he has not used it but for maybe 4-5 track days and now is forced to part it all out. The car has 7000 miles on it as does all the parts listed below... unless listed rebuild.
VTC Solenoid $50.00
Crank Sensor $30.00
K20 Dip Stick $10.00
K24 Dip Stick $10.00
K20 Crank Pulley $50.00
K20 Chain Cover $45.00
K Series Cam Sensors $25.00 ea.
K Series Crank Bolt $5.00
K24A4 Rocker Assy. $100.00/ K24A4 Cams $50.00/ VTC Gear $30.00/ Exhaust Gear $15.00
TW Sensor $10.00
VSS Sensor $60.00
Knock Sensor (Green) $35.00
Knock Sensor (Black) $30.00
K Series Chain Tensioner $25.00
Head Bolts $20.00 (Per Set)
Type S cams $100.00 (Two Sets Avail.)
Type S Intake Valves $20.00 (Set of 8)
Type S Exhaust Valves $20.00 (Set of 8)
Type S Intake Springs $20.00 (Set of 8)
Type S Exhaust Springs $20.00 (Set of 8)
RBC Gear $45.00
Fixed Exhaust Gear $15.00
Valve Cover (Acura) $40.00
Type S Throttle Cable $15.00
2002-2004 RSX Type S Engine Harness (NEW) $230.00
K24A4 Oil Pump $35.00
RSX Type S Power steering Pump and Tank $50.00
Engine Cover $15.00
RSX Type S Shifter Box $100.00/ Short Shifter Adapt. $50.00
RSX Type S Shift Cables $200.00
Clutch Master Pressure Plate $125.00 (Less then 100 miles)
Clutch Masters 4 Puck Disc $100.00 (Less then 100 miles)
Aluminum Flywheel $150.00 (Less then 100 miles)
Integra Type R Bra $100.00
RSX Factory Honda Car Cover $100.00
Type S DSS 2.9 Axles $400.00 (Less then 100 miles) Need to pick up the other side...
Stock Type S Axles $100.00 (Inner Joint on One needs to be rebuild)
Type S Tranny w/ Mugen LSD $1500.00 (Less then 100 miles on re-build and Diff)
**** Can part out LSD w/ exchange of a stocker... $800.00****
PRB Manifold $40.00
T/Body $280 Complete
Alt. $100.00 w/ AEM Pulley
Starter $80.00
Half Shaft $80.00
Water Pump SOLD/ Tensioner $30.00 / PS Pump w/ AEM Pulley $45.00
T-Stat and Lines $80.00
Water neck $25.00/ Sensor $30.00 or neck w/ Sensor $50.00
RSX Clutch Master Tank $10.00
RSX Type S Prop Valve $30.00
RSX Type S Master Cylinder $60.00
RSX Type S Booster $100.00
EP3-R Rear Rotors (100 miles) $40.00
RSX Type S ABS $50.00
RSX Headlights Pr. $150.00
RSX Booster Line $20.00
RSX Type S Arm-rest $60.00
DC Sports Shift ***** $35.00 ea.
AEM Coil Cover $40.00
AEM Universal Fuel Pressure Regulator Pt# 25-300R (NEW) $80.00 **No Fittings**
AEM Fuel Pressure Regulator Pt# 25-300C (NEW) $80.00
AEM Fuel Pressure Regulator Pt# 25-300R (NEW) $80.00
AEM B Series Cam Gears Pt# 23-802C (NEW) $100.00 pr.
AEM B Series Cam Gears Pt# 23-802B (NEW) $100.00 pr.
Porsche 996 Front Calipers (NEW) $600.00 **Includes Pads**
Project Kics Lug Nuts $100.00 (****ing Bad ***)
RSX Type S Mirrors Pr. $150.00 (Color Code R-507P) Also Have a complete A-Spec Under-body Spoiler Kit $250.00,
Front Bumper $100.00, Doors w/ Glass $200.00 ea., Fenders $80.00 ea., Hood $100.00, Trunk w/ Glass $200.00, Rear Bumper $100.00, and Tail-lights Pr. $100.00
RSX AC Compressor $150.00
RSX rear-view mirror $15.00 (Universal)
Coils $80.00 (Set)
Hasport RSX Pass. Mount $40.00
RSX Rear Mount $25.00
RSX Pass. Mount $35.00
RSX Drivers Mount $20.00
RSX Front mount $20.00
RSX Type S MUGEN Ft. SwayBar $150.00
RSX H&R Full Coilovers $550.00 (Price Reduced)
RSX Titanium Rear Strut Bar $150.00
RSX Titanium Front Strut Bar $125.00
RSX Tie-rods $40.00 pr.
NEW Honda Battery $30.00 (Pick-up Only)
RSX Type S LCA & Knuckles $150.00 (Price Reduced)
RSX Type S Fuse Box $50.00
Radiator $100.00
Radiator Over-flow Tank $10.00
AEM EMS w/ Wide-Band $900.00
DC Sports Exhaust $200.00
AEM Cold Air $90.00 (Price Reduced)
Lenso 17" x 7" 5 x 114 +42 $300.00 w/ NEW 205/40 Toyo T1S $600.00 or Tires Only $350.00 (Price Reduced)
Motegi Track Lite 17" x 8" 5 x 114 +45 $550.00 w/ Slightly Used 235/40 Toyo RA1 $900.00 or Tires Only $400.00 (Price Reduced)
Sparco Seat Brackets $80.00
Sparco Circuit Seat $400.00
Sparco 4" Harness $100.00
Turbonetics Evolution Gate (NEW) $200.00
Turbonetics Raptor BOV (NEW) $200.00
Spearco FMIC (NEW) $350.00
JDM 4 x 114.3 Conversion $300.00
DSS Level 2.9 H22 Axles for Hasport EKH2 Kit $450.00 (NEW)
1996-1998 Civic Front End Harness $30.00
H22 Engine Harness $80.00
B18C5 Engine Harness $125.00
Shift linkage W/ ES Busings (Came from EK4 w/ B18C5) $50.00
CTR Power Mirrors (Not Power Folding) $250.00 **Fits 1996-2000 Civic 2dr./ 3dr.**
More parts to be added as we tare the car apart...
Modified by Duckiller00 at 6:21 AM 8/29/2007
VTC Solenoid $50.00
Crank Sensor $30.00
TW Sensor $10.00
VSS Sensor $60.00
RBC Gear $45.00
Engine Cover $15.00
PRB Manifold $40.00
Starter $80.00
Half Shaft $80.00
Coils $80.00 (Set)
Radiator $100.00
Thanks!
Just parted out a 2003 Acura RSX Type S. The parts from that car got me off my *** to sell the rest of my collection.
KIWI
Jan 10, 2006 05:18 PM
