Tires........
Old Jun 14, 2002 | 08:43 AM
Turbo Powa's Avatar
Default Tires........
About a week ago I noticed a small bunp coming out the the tires side. What does this mean? Too much air? I let some air out... like 5 psi out. Then I checked it today and it was gone. Anyone know what happened? Is my alignment off? I got new rims and tires about a month ago but they didnt do an alignment. I hope you all can help me out cuz I dont want my $950 Rims to get screwed.
Old Jun 14, 2002 | 09:04 AM
Turbo Powa's Avatar
Default Re: Tires........ (Civic LX 29)
Anyone?
Old Jun 14, 2002 | 09:16 AM
Bakeoff's Avatar
Weak spot in the side wall of the tire. I've heard of people running with tires in the same condition for a few years without any problems. I'd be scared as hell to do, but I pound on my car... Call up the place you got the tires from and see if they'll exchange one for you.
Old Jun 14, 2002 | 09:21 AM
Turbo Powa's Avatar
Default Re: Tires........ (Bakeoff)
but when I took alittle air out it went away. Could too much air be the problem?
Old Jun 14, 2002 | 10:03 AM
jdmciviceg's Avatar
New User
Did you hit a pothole or large bump in the road? I've had two tires that I had to replace because of a "bump" on the sidewall created by potholes.
Old Jun 14, 2002 | 01:06 PM
NiiS's Avatar
Default Re: Tires........ (jdmciviceg)
same experience here. time to get replacements.
Old Jun 14, 2002 | 01:33 PM
PSU's Avatar
PSU
formerly DxHatchback
Default Re: Tires........ (sinister)
that happened to my mom in her coupe before. its from hitting a pot hole and a belt inside the tire breaking. you should really have it fixed.
Old Jun 14, 2002 | 08:02 PM
ryanhook's Avatar
Had that happen to one of mine. The sidewall was weakened by an impact of some sort... most likely a pothole. If they're replacements (not the original ones from the factory/dealer) and they're a good brand name tire, then you should have a "Road Hazard" warranty on your tires. That warranty will cover damage like that, though you will pay a little depending on your tire wear. I had that happen to my Michelin Pilot XGT H4s and all I paid was $20 for wear.
Old Jun 14, 2002 | 10:26 PM
TurboBumblBee's Avatar
Default Re: Tires........ (ryanhook)
correct.. i work at a tire center at costco and we will road hazard any tire that is bought from us that has a defect in the tire such as this bubble.. it can be very dangerous and can cause the tire to BLOW OUT w/ out any notice and cause a very bad situation on the road.. get it fixed asap.. ive seen really bad blow outs at work and just wondered to myself, how did they control the car to get it pulled over? specially if its on the front tire, a front tire blow out you have NO control of the car and very scary.. get it replaced or buy a new tire.. most places will replace the tire if its there brand or a common one like michelian, bridgstone, or whatever..
Old Jun 18, 2002 | 11:28 AM
Turbo Powa's Avatar
Default Re: Tires........ (95CivicEX)
I highly doubt that a performance auto shop will replace them but thanks for all the help!
Old Jun 18, 2002 | 11:33 AM
BROOD's Avatar
Do you have a photo of the lump? I can better tell what is going on with a look.
It could be as serious as a separation to a little as overlapped belt seams. Either way you could still get new tires out of it, if you have a road hazard warrenty.
Old Jun 18, 2002 | 11:40 AM
Turbo Powa's Avatar
Default Re: Tires........ (SLPR)
The manufacture provides the warrenty right? I cant get it replaced from the store I bought it from?
Old Jun 18, 2002 | 01:54 PM
BROOD's Avatar
It really depends....I've seen it go many ways.
The maufactuer clears it up (rarely)
The store you bought them at clears it up
or You clear it up by buying a new tire.
I can't really give you a good guess.
Old Jun 18, 2002 | 02:28 PM
Turbo Powa's Avatar
Its all good SLPR you gave me great information anyway, so I thank you for that. Other than that, I think I'll get it fixed for $30.00. If anyone got any other suggestions then post away!!
Old Jun 18, 2002 | 04:41 PM
ejprimo's Avatar
that happened to my tire and im lucky it didnt blow out when i was doing 80 cuz it eventually it went flat overnite
Old Jun 18, 2002 | 06:33 PM
deepnite's Avatar
id say it was a weakness in the sidewall..continental tires are known for this condition..had them on a chevy at one time and the dealer said it was normal on all the cars..to me that meant that customers were being screw d and GM didnt want to help at all..*hope any GM people read this*..i play d it safe and went down to America s tires for a set of BF Goodrich s.. at the time
Old Jun 18, 2002 | 09:34 PM
Turbo Powa's Avatar
Default Re: Tires........ (deepnite)
thanks!!
Purple-skunk
Wheels
Feb 22, 2013 07:19 AM
B18C_JDMDC2
Jul 13, 2010 06:44 PM
CRX 2.0V-T
Oct 18, 2006 01:55 PM
A.E Motoring
Apr 26, 2005 10:46 AM
azian21485
Feb 9, 2005 08:03 AM
