another car wont start thread PLEASE HELP
Old Aug 28, 2007 | 10:30 AM
myhatch98's Avatar
Default another car wont start thread PLEASE HELP
im working with a 1990 crx si. car was running obd0 and had an ls motor then the car stopped running so my first thought was distributer. replacing the distributer did not do the trick. car will turn over just fine seems like it wants to start but it doesnt. not even starter fluid does the trick car is getting:
good spark,
fuel,
changed main relay,
checked all the fuses
changed batter
changed fuel pump
check fuel pressure
checked grounds
changed ecu
tried a friends distributer from a running car
compression on car is fine
ran out of ideas. sumone please help
myhatch98's Avatar
Default Re: another car wont start thread PLEASE HELP (myhatch98)
I also checked the timing.
Old Aug 28, 2007 | 10:52 AM
CW-ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhatch98 &raquo;</TD></TR><TR><TD CLASS="quote">I also checked the timing. </TD></TR></TABLE>
X2
Old Aug 28, 2007 | 10:58 AM
myhatch98's Avatar
Default Re: another car wont start thread PLEASE HELP (CW-ITR)
i checked and everything is TDC its perfectly timed
Old Aug 28, 2007 | 11:50 AM
Street Racer X's Avatar
do you have power at the ECU? I would look at the ECU pinout chart and wiring diagram and check for power at the different pins especially the ECU power wire. Im sure if you search you will find a pinout chart for an LS motor
Old Aug 28, 2007 | 12:39 PM
myhatch98's Avatar
Default Re: another car wont start thread PLEASE HELP (whitecivichatch90)
ecu has power.....
Old Aug 28, 2007 | 12:57 PM
gp70hs's Avatar
Have you checked your fuel pressure. I had a 91 Wagovan that was giving me fit's. It turned out to be the pressure regulator was not opening, which was putting to much pressure on the fuel delivery system. The fuel system ended up having a hose, in the fuel tank, which had separated, but not completely burst. Consequently it was not getting the right pressure or fuel delivery, to the injectors.
Old Aug 29, 2007 | 07:38 AM
myhatch98's Avatar
Default Re: another car wont start thread PLEASE HELP (gp70hs)
yes i have checked the fuel pressure and it is where it is suppose to be... any other ideas
Old Aug 29, 2007 | 08:16 AM
BlakeJ53's Avatar
What engine harness are you useing? HF or SI
Old Aug 29, 2007 | 06:53 PM
myhatch98's Avatar
Default Re: another car wont start thread PLEASE HELP (BlakeJ53)
SI engine harness
airjordan604
Jul 3, 2009 12:24 AM
rodvang
Dec 25, 2007 08:37 AM
vtecsi00
Oct 24, 2006 10:50 PM
Lsos
Mar 4, 2005 11:49 AM
93DA530
Nov 24, 2003 11:10 AM
