check engine code 20 EDL
Old Aug 28, 2007 | 09:08 AM
jdm_r1's Avatar
Default check engine code 20 EDL
alright team, help me fix this trivial issue. When I first start my car, engine light is on, the car bogs below 2K clears up until 4K where it won't move AT ALL. It just won't rev past 4K. But sporadically the engine light will turn off and it's back to normal. The engine code is 20 which is the EDL. Suggestions?
Old Aug 28, 2007 | 09:31 AM
d16y8hatch's Avatar
Default Re: check engine code 20 EDL (jdm_r1)
That's ELD, electronic load detector. That usually goes bad with poor grounding, check the ground connection at the thermostat housing. If your ground points are fine, replace the main fuse box (under hood). The ELD is built into the box, I found one for my car for 10 buck at a local junk yard, problem solved.
Old Aug 30, 2007 | 08:36 AM
jdm_r1's Avatar
thanks, I'll do that.
STR8__
K Series
Mar 7, 2017 08:20 AM
blaze.1
Sep 24, 2009 11:04 AM
jdmazm
Apr 21, 2005 07:58 PM
wadafa
11
Oct 3, 2002 03:49 PM
akirax
May 2, 2002 08:36 PM
