brand new clutch problem.
Old Aug 28, 2007 | 09:07 AM
95exdsmkilla's Avatar
Default brand new clutch problem.
Ok, I just bought Clutchnet Duel diaframe pressure plate and 3puck clutch...
Whenever I tried to put it in gear when car is on does not go into gear. but When I put it in the gear when car is not on... when i tried to started car just moves and dies like clutch is not disengaing
please help thank you very much!
Old Aug 28, 2007 | 10:18 AM
Archidictus's Avatar
Unceasing Measure
Default Re: brand new clutch problem. (95exdsmkilla)
Did you install this yourself, I'm assuming? Sounds like something's in backward or the throwout bearing is missing or you failed to bleed the clutch cylinders after installation.
Let us know exactly what you did and we can tell you exactly what is wrong.
Old Aug 28, 2007 | 10:32 AM
MonkeyBoy668's Avatar
Default Re: brand new clutch problem. (Archidictus)
Yeah, if it's a hydraulic clutch, it could be that the clutch isn't disengaging because the clutch hydraulics have bubbles or has run dry. So you could check the clutch fluid.
It's pretty much impossible to say what the problem is because we need more information about the clutch install, just like Archidictus said...
Modified by MonkeyBoy668 at 10:44 PM 8/28/2007
Old Aug 28, 2007 | 05:46 PM
Brick Top's Avatar
Default Re: brand new clutch problem. (MonkeyBoy668)
if everything was done correctly, the clutch pedal could need adjusting.
legend97
Transmission & Drivetrain
Jul 6, 2017 07:45 AM
mikeycivic
Jun 4, 2007 05:32 PM
sazaks
Mar 10, 2003 05:20 AM
