Distributor the same on 90 civic DX and 89 CRX SI?
My 90 civic DX died today with the 1.5 litre dx motor, and I believe it may be the distributor. I have an 89 CRX SI parts car, will the distributor be the same?
Any help would be great, thanks
Yes it will work but you have to re-pin/swap the plug.
The Si has an extra sensor the DX doesn't use, so you need to use the DX plug on the Si distributor and only use the wires on the original DX plug.
Look at the wire colors at the plug on both distributors and match them.
the SI distributor has a crank sensor and the DX does not. The DX distributor will not work on a car with an Si computer but in your case you dont have to worry about the sensor and like the previous post said check the wiring.
Hmm I guess I will have to check the wiring when I get home...if the colors dont match am I hooped, or is there any diagrams that would show if they are the same but different color?
Very easy. The only tricky part is removing the pins out of the plug if you have never done it.
Look at the Si distributor plug, it is round and it has 7 wires.
Look at the DX distributor plug, it is rectangular and it has 5 wires.
The DX distributor plug does not have the blue green and blue yellow wires the Si distributor has.
keep track of where the wires go and just sawp them, they are the same except for the blue/green and te blue/yellow which the DX does not use.
Thanks very much for that, I appreciate it a lot as I need to try and get this thing running tonight. I am at the point where even if I just take them off and butt-connect them together that would even be ok. I will study both and write every color etc. down in case I make a mistake
OK maybe somebody can help me with my situation...
I was driving the civic (DX) yesterday, and the car suddenly started missing slighly and I lost a bit of power, then it fully died on me and would not start. So I checked the code and it was code 8, which I believe is the top dead center sensor. I talked to a few people and they said thats in the distributor and this is a common thing to fail.
So I got that SI distributor, and tried matching the wires , but the car still wouldnt start. I literally tried a lot of combinations and there was still no spark. Any other suggestions on what it could be? I am goingto try and find an actual wiring diagram to make sure I amdoing it right..
Thanks for any help
Thanks for any help
your 89 crx, do you possibly have the heater control unit and can you possible post a picture of it if so, i have an 89' si with b16 and i need a heater its super cold in wisconsin and i need heat, also i gotta problem, my car the other day just suddenly died after about 5 minutes of running, about ten minutes after she started up and drove all day with no problems, then yesterday (next day after first time), i drove my car all morning and in 5th gear going about 55mph and all sudden BOOM! my tach dropped to 0 and bogged out till i had to stop and wont start again, checked plug wires connected to coil and no spark, turns over but wont fire, any possible answers please help
1slowEF9
10
Jan 17, 2007 04:13 AM
classciv
Apr 2, 2006 03:30 PM
Agent Daimon
Dec 17, 2002 03:42 AM
