B18C1 GSR Swap - Clean - Legit - Turbo ready! (SoCal)
I have a 1996 B18C1 GSR Swap to sell. This is an clean, legitimate swap with vin, papers and receipts. The swap is turbo ready and comes with the following:
All of the following have aprox 10,000 miles unless otherwise noted:
1996 B18C1 - COMPLETE longblock down to the alternator. Had about 56,000 miles when installed in 98 Civic EX in march of this year. estimated about 66,000 miles currently. New oil pump, water pump, and timing belt, as well as cam seals, cam cover gasket etc.
B18C Transmission
Re-surfaced flywheel
Clutch Master FX200 Clutch
Oil filter sandwich adapter for turbo feed line and gauges
Stainless steal Turbo oil feed line installed
Professionally tapped oil pan for turbo return line
RC 370CC injectors
NGK plugs, wires, cap, and rotor.
Complete set of Innovative Motor Mounts
GSR axles (need to be re-booted which is easy, boots were disassembled during swap removal)
GSR shift linkages
FULL Wiring Harness UNCUT!
Chrome Pro P28 ECU - chiped / Dyno Tuned by Whitefield Racing for 7 psi with the rc370 injectors on this motor.
OBD Conversion harness
You need an exhaust mani, a turbo, intercooler and piping and this thing is ready to tear up the streets!
Photos coming right up! (the swap is in the back of my hatch, in the garage. I haven't found enough people to help me lift it out, so I'm driving my brother's car since hes at school)
$2900
Modified by Eyal 951 at 2:26 PM 8/30/2007
B18C Transmission
RC 370CC injectors
GSR shift linkages
$2900
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sparkles »</TD></TR><TR><TD CLASS="quote">Bump for the ultra rare paper work!</TD></TR></TABLE>
You don't get that kind of security often when buying a Honda motor!
Eyal 951
Oct 15, 2007 03:44 PM
Eyal 951
Oct 1, 2007 01:29 PM
Eyal 951
Sep 8, 2007 11:07 PM
