Burning oil smell....gasket or seal?
Old Aug 27, 2007 | 07:07 PM
EK79's Avatar
Default Burning oil smell....gasket or seal?
I noticed lately that the under carriage of my EK looks like i drove through an oil field. i searched and looked the possibilities are a bent oil pan or bad gasket or in need of a new rear main seal my car has a B16 and i dont have any slippage problems with the clutch but what i cant find is do you use sealant when replacing the oil pan gasket or not i want to change this first before i drop my tranny and have a go at the the rear seal anyone know ......THANKS IN ADVANCE
Old Aug 27, 2007 | 07:27 PM
smileycvc's Avatar
Default Re: Burning oil smell....gasket or seal? (EK79)
Its up to you. If you do use sealant make sure both the block and oil pan surface are very clean before you apply it.
aholeb18's Avatar
start at the top and work down. how many miles? does the oil run down or blow back from the valve cover gasket, or under the timing cover? your best bet is to buy some engine oil dye from napa or local auto parts store, and use infrared light to pick up where it's leaking out. that's what any dealership would do.
Ser1N
Jan 26, 2020 02:26 PM
jnb426
Jan 9, 2008 04:08 PM
Kapetan
Oct 19, 2006 08:35 AM
geminis2k
Mar 29, 2004 08:00 PM
overdose
Apr 27, 2003 02:03 PM
