Skunk2 blowout sale!!!! cheap !! ready to ship !!
In stock Skunk 2 Racing Products!! We will match or beat any advertised price, lowest prices guaranteed!
Pro Series Intake Manifolds:
* Increased Plenum and Runner Size
* Oversized Throttle Body Opening
* Made From High-Grade 356 Aluminum
* OEM Quality Shell Molded Casting
* Nitrous Mounting Bungs
* Skunk2 Acid-Etched Nameplate
* Broadest Usable Powerband
* Vacuum Tested To Ensure Quality
* Utilizes Stock Sensors 64mm Throttle Body Opening That Can Be Port Matched To 75mm
* Increased Plenum Volume
* 8” Tapered Runners For Maximum Torque and Power Increase
* CARB EO Approved
1990-01 LS/RS(B18A-B) Part# 307-05-0280 (shown below) or
1994-01 GSR(B18C1) Part# 307-05-0270: $265 Shipped!
Pro Series B-Series DOHC VTEC Throttle Bodies: Shipped!
• High Flowing Large Bore Capable Of Supporting 1000 HP
• Gains As High As 50+ HP On Forced Induction Applications
• Durable and Corrosion Resistant Hard Anodized Finish
• Uses Factory Throttle Cable
• CNC Forged AL6061-T6 Billet Aluminum
• Sealed Bearings For Smooth Operation
• MAP Sensor Relocated To Bottom side For Cleaner Look
• Eliminates Factory Waterlines For Cooler Operation
Available in 60, 66, 68, 70mm: $285 Shipped!
Combo: Intake Manifold and Throttle Body: $535 Shipped!
Lower Control Arms:
# NEW! Clear Anodized finish (silver)
# CAE is used to analyze the strength and performance
# High-Quality CNC Machining
# Adjustable Sway Bar Mounting Holes
# Over 25% Lighter than Stock
# Polyurethane Bushings that Act as Bearings
# Forged AL-2024 I-Beam Design for Maximum Strength and Resistance to Twisting and Bending
88-95 Civic, 90-01 Integra Part# 542-05-0110: $200 Shipped!
Silver Anodized:
Gold finish "Orange":
Rear Camber Kit:
# High-strength Forged Ends
# CNC Machined AL7075
# Hard Anodized Finish
1988-00 Civic CRX, Del Sol(ALL); 1990-01 Integra (ALL) Part# 516-05-0500: $170 Shipped!
Front Camber Kit:
# The Tuner Series features Skunk 2 industry standard one-piece forged ball joint that they pioneered the use of back in 2000.
# The new "square" washer plates tie the two bolts together to improve clamping and prevent distortion of the bolt slots.
Integra 94-01/Civic/Del Sol 92-95:
Tuner Series Front Camber Kit - $190 Shipped!
Pro Series Front Camber Kit - $210 Shipped!
Pro Series +/- 4 Front Cmaber Kit - $235 Shipped!
Combo Front and Rear:
Pro-S Coilovers:
# Dual Tube Design
# Non-Adjustable Precision Valving
# Shortened Shock Body and Stroke
# Adjustable Ride Height
# One-Piece Machined Bodies
# Uses Factory Upper Mount
# Some Kits include Forged Mounts
# SAE9254V Racing Springs
88-00 Civic/Crx/Del Sol; 90-01 Integra Part# 541-05-5700: $700 Shipped!
CALL or PM FOR OTHER APPLICATIONS, WE CAN GET ALL!
-miles@tunerzimage.com
AIM: TunerzImagemiles
email/paypal: miles@tunerzimage.com
ph: 909-628-1707 or toll free 1-877-488-6379
* CARB EO Approved
Lower Control Arms:
Silver Anodized:
Rear Camber Kit:
Front Camber Kit:
Pro-S Coilovers:
# Dual Tube Design
boostedb20ek
Aug 12, 2011 08:16 AM
importdps
Honda Civic (2006 - 2015)
25
Nov 13, 2010 01:41 PM
yobs00
Nov 10, 2008 02:12 PM
