DA teggy rear brakes on hf crx??
Old Aug 27, 2007 | 05:33 PM
socalrex88's Avatar
Default DA teggy rear brakes on hf crx??
okay im lookin at some threads about putting rear disc setup....um one says that you need to drain all fuel in the tank to connect brake lines and hose etc... and this other one said like you need crx si e brake cables or that you can use the e brake cable that came with the rear brakes...is this true correct me if im wrong... also can you swap any DA rear disc on your crx say a four dour teggy... thanx for reading... if you can send me another or better thread about putting in rear disc conversion i dont really understand the one im looking at.. thank you for your time!!
Old Aug 27, 2007 | 06:04 PM
eda6's Avatar
Default Re: DA teggy rear brakes on hf crx?? (socalrex88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socalrex88 &raquo;</TD></TR><TR><TD CLASS="quote">um one says that you need to drain all fuel in the tank to connect brake lines and hose etc.. </TD></TR></TABLE>
not necessary
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socalrex88 &raquo;</TD></TR><TR><TD CLASS="quote"> and this other one said like you need crx si e brake cables or that you can use the e brake cable that came with the rear brakes...</TD></TR></TABLE>
crx si e brake cables are preferred. teg cables are longer but will still work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socalrex88 &raquo;</TD></TR><TR><TD CLASS="quote">also can you swap any DA rear disc on your crx say a four dour teggy...</TD></TR></TABLE>
yep. reuse ALL crx control arms.
http://www.fourthgenhatch.net/reardiscswap.html
Old Aug 27, 2007 | 07:52 PM
socalrex88's Avatar
Default Re: DA teggy rear brakes on hf crx?? (eda6)
awesome!! thanx for the site you gave me ill look in to it and try it possible soon when i have time.. ill post up some pics of how things turn out! peace!
Old Sep 7, 2007 | 04:24 PM
socalrex88's Avatar
hey whats the diff between si dx hf brake cables?? and another ques. i was at the junk yard today trying to take off the 40-40 proportion valve off a DA with an open end 10 mm and that motherchukka just stripped so i was like forget it......inotice there was an article on here that said like youd have to burn the steel lines a lil to get it unstuck,but isearched and searched but keep ending up with nothing? is there another way to get it off without stripping it? because i wouldnt wanna f.... up another one. thanx
Old Sep 7, 2007 | 04:27 PM
msinsky14's Avatar
drum brake cables hook up to the drums differently than to calipers.
but definately get 1991 si brake lines, stainless steel with a 40/40 proportioning valve will give awesome brake pedal feel!
Old Sep 7, 2007 | 04:29 PM
CRX Toad's Avatar
Si cables are disc brakes, CRX and HF brakes are drum. It will not work to put drum cables on a disc.
I have gotten the brake lines off with no issues just have a little WD40/Liquid wrench/etc with you are something but I have never burnt anything to get it unstuck when dealing with brakes.
Old Sep 7, 2007 | 05:54 PM
socalrex88's Avatar
Default Re: DA teggy rear brakes on hf crx?? (CRX Toad)
hold on im getting confused...are you saying that 90 91 crx si come with rear discs? and that i should get ebrake cables from crx si ?? well what about the ebrake cables that came with the DA?? and say iuse the ebrake cables from DA ..do i have to make any adjustments to make them work?? iknow there a tad longer..
Old Sep 7, 2007 | 06:46 PM
dubzz24's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socalrex88 &raquo;</TD></TR><TR><TD CLASS="quote">hold on im getting confused...are you saying that 90 91 crx si come with rear discs? and that i should get ebrake cables from crx si ?? well what about the ebrake cables that came with the DA?? and say iuse the ebrake cables from DA ..do i have to make any adjustments to make them work?? iknow there a tad longer.. </TD></TR></TABLE>
Yeah, 90-91 CRX Si's were the only EF's that came with rear discs. If you want the e-brake cables to fit properly you'll need the ones from a 90-91 CRX Si. You can use the DA teggy ones, but they're too long and hang pretty low and can rub on the trailing arm etc. I've done it with no problem, but the Si cables are definately fit MUCH better if you can get them.
And for your wrench issues, you need to get crow's foot or flare nut wrenches.
Look like this:
Old Sep 7, 2007 | 07:32 PM
DustinRose's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socalrex88 &raquo;</TD></TR><TR><TD CLASS="quote">i was at the junk yard today trying to take off the 40-40 proportion valve off a DA with an open end 10 mm and that motherchukka just stripped so i was like forget it....</TD></TR></TABLE>
i cut the lines with side cuts, when i got mine at the junk yard
Old Sep 7, 2007 | 08:22 PM
~sp33~'s Avatar
EFB055
Default Re: DA teggy rear brakes on hf crx?? (dubzz24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dubzz24 &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, 90-91 CRX Si's were the only EF's that came with rear discs. </TD></TR></TABLE>
In the US,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abram_quito &raquo;</TD></TR><TR><TD CLASS="quote">GO W/ DA DISC BRAKES
WITH CERAMIC ONES AND BIG *** ROTORS
BETTER BRAKING
AND FASTER DECELERATION
HAVE A GREAT DAY</TD></TR></TABLE>
Oh my god
Old Sep 7, 2007 | 08:35 PM
~sp33~'s Avatar
EFB055
Default Re: (abram_quito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abram_quito &raquo;</TD></TR><TR><TD CLASS="quote">DA helps improve better braking
and improve better reaction time to the
fwd wheels to stop much faster</TD></TR></TABLE>
Old Sep 8, 2007 | 01:24 AM
socalrex88's Avatar
thanx alot! ill get those crow feet or flare nut wrenches today and go back to the junkyard....well its gonna be hard to find 90-91 si ebrake cables...then i can just hide the cables or tuck it somewhere where it wont get in the way of anything then i guess right?
Old Sep 8, 2007 | 01:30 AM
Red_ED8's Avatar
Correct me if I'm wrong but doesn't only the 91 CRX SI come with rear disc and not the 90? I got a 90 CRX SI with no rear disc, maybe previous owner sold them
Old Sep 8, 2007 | 02:15 AM
SIred91's Avatar
Rainman
BETTER BRAKING
Just take your chode sucking *** into the bathroom and fill the tub with warm water.
Then get a razor blade and cut from your wrist to your elbow.
Then hop in the tub and wait for that warm fuzzy felling to overwhelm you.
IF THAT DONT WORK, SHOOT YOURSELF IN THE ******* HEAD.
Old Sep 8, 2007 | 10:12 PM
socalrex88's Avatar
Default Re: (SIred91)
come on guys! no need to argue over about.....the guy was just giving some advice (that im not goin to do whatsoever ) and remember this is a motherchukken thread!!
Old Sep 8, 2007 | 10:51 PM
Crx dude's Avatar
Default Re: DA teggy rear brakes on hf crx?? (Red_ED8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">Correct me if I'm wrong but doesn't only the 91 CRX SI come with rear disc and not the 90? I got a 90 CRX SI with no rear disc, maybe previous owner sold them </TD></TR></TABLE>
A 90 crx si has disc brakes in the rear too.
civicsleeper97
Jan 5, 2006 12:37 PM
SPL KID
Apr 26, 2005 03:55 PM
HatchBox
34
Dec 5, 2004 12:09 PM
b16crx0062004
Aug 27, 2004 10:18 PM
BAZ
28
Sep 21, 2003 10:24 AM
