4dr fog lights
Old Aug 27, 2007 | 05:31 PM
mortificationrock's Avatar
Default 4dr fog lights
Hey does anyone have the wiring diagram for a set of DEPO fog lights for a 4dr? Thanx to anyone who inputs
Old Aug 28, 2007 | 01:35 AM
BlueIntegraBoy's Avatar
Default Re: 4dr fog lights (mortificationrock)
http://www.jdmlyfestyle.com/oe...g.htm
Old Oct 14, 2007 | 08:37 PM
chinochanginc's Avatar
im looking to buy some... how are your depos??
urs have the clear lens or the blue one??
Old Mar 13, 2008 | 08:35 PM
superchill27's Avatar
fog light install for 96-00 civic si, ex,lx and dx 2d/4dr (maybe for 92-95 eg or ej too)
steps
-remove bumper (make room for fog light some cutting required)
-locate 1 pin connector behind reservoir bottle wrapped in blue tape free it (its called sub harness)
route wires through the same hole engine harness runs through
interior wiring part
-remove driver side under panel cover
-located the interior 1 pin connector sub harness(behind fuse box) be patient you'll find it.
-relay mounting look for existing ground bolt and remove bolt and remount in same spot
placing switch- extra space next to the mirror switch. pop it out
last thing. always test it and align if needed
hopes this helps you
ojasia
Jan 6, 2015 09:14 PM
dc4teg95
Oct 22, 2010 06:38 PM
michael_c
May 5, 2008 08:38 PM
alejandrojn
Mar 26, 2004 11:29 AM
hYbRiD EeEkAy
Feb 2, 2004 04:29 AM
