after swap battery fuse blows once batterys connected? wtfbbq
alright swapped an obd1 d back into my ob2 EK for the winter while i build the B up and when i connect the power to the battery a part of my trans lightly sparked near the clutch vents and then my battery fuse went.
any clue guys?
thanks in advance!
Modified by vtecftw at 7:42 PM 8/27/2007
any clue guys?
thanks in advance!
Check your grounds. The one to the battery is probably not connected properly. The spark you saw near the tranny was the ground that goes to the tranny trying to compensate.
Clean up and make sure all ground in the engine bay are tight and in good shape.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">or a positive from your starter is grounding out</TD></TR></TABLE>
x2
x2
Well, are the start power wire and ground on the starter itself all hooked up correctly? That BLK/YEL wire has a small connector on the starter solenoid casing, make sure it tight. Might also want to look for breaks in the starter power wire from the battery to the starter.
The starter ground wire that connects to the side of the solenoid is securely connected. And besides that ground there is only one other connection for the main power and such wich is also connected.
the valvecover ground is connected and the trans ground is connected along with the rest of the harness grounds
Nevermind, it's already been covered. ****. Reading comprehension owns me.
Are you sure that you wired everything correctly? I'd just start tracing wires, there's nothing else that you really can do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Buy a new pos terminal cable - your short is there.
It's like 30 bux from honda. Problem solved.</TD></TR></TABLE>
^Ya or not, did you connect the white wire to the alternator? It is the one held on by a 10 millimeter nut
