Accord Hesitates after start in Idle
Did a search no luck.
2000 4cyl ex,110K good spark plugs, wires, oil, air filter etc.
Sometimes after I start the car and sit in idle, the car will hesitate like it wants to stall but does not. It is bogging down. If I step on the gas pedal hard enough it will go away. I don't know if it is a computer problem, or a fuel problem. I haven't cleaned the fuel nozzles but don't know if that is the problem. After startup, it is usually fine the rest of the trip. Any suggestions?
Thanks
Thanks
heres what u can try, JB intake system cleaner, clean the throttle plate and shoot the JB stuff in the intake it gives u the directions on the can, also get some fuel injector cleaner, poor in gas on empty tank and run it through acouple day, see if problem gets better. If you have never done this before atleast this is a cheap tuneup and hopefully fix
