**** DA radiator.... which fan to use for direct fit?
EF hb si with gsr
I replaced crusty oem one with napa DA dual core fan for better cooling
I tried to place by stock EF fan back on but the holes did not line up and also the bottom plastic lip did not hook up to the DA radiator...
would DA radiator work in EF bay with b series swap or the fan too large?
why didn't you just get a new radiator for the EF its still a full core radiator..but since you already bought the DA radiator you can probably use 2 10" slim fans for it.
I have the same setup. There were 2 different rads for the da's. I think 2 different manufacturers that honda used. They had different mounting points for the fan. I got a universal one that had both sets of mounting points. The bottom clips(at least one as I can remember) and both top lined up to my stock crx fan. I had to use a heat gun on one arm of the fan to bend it slightly it was off by like 1/4". It went bad later and just got a da fan off ebay for $5. it fits fine with a bswap.
Charlie Moua
12
May 11, 2009 03:20 PM
