from 81.5mm going to 82mm???
Old Aug 27, 2007 | 02:55 PM
DA_JDM's Avatar
Default from 81.5mm going to 82mm???
Ive seen people going that direction with almost identical set-up and lose power is this normal or going 82mm instead of 81.5mm usually will make more power on a b18c???
Old Aug 27, 2007 | 02:59 PM
all-mtr-teg's Avatar
Default Re: from 81.5mm going to 82mm??? (DA_JDM)
I think bigger is better, that's why people sleeve their blocks and go 84-85mm. But if you go too much on stock sleeves, that's asking for trouble. I think 82 is the max for stock sleeves, some even say 81.5mm is the most you should bore.
Old Aug 27, 2007 | 03:05 PM
DA_JDM's Avatar
Default Re: from 81.5mm going to 82mm??? (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">I think bigger is better, that's why people sleeve their blocks and go 84-85mm. But if you go too much on stock sleeves, that's asking for trouble. I think 82 is the max for stock sleeves, some even say 81.5mm is the most you should bore.</TD></TR></TABLE>
Thanks...i have no choice on going 82 cauz ive dropped some valve and blew a piston on my 81.5 built And im not a 2.0liter guy so i wanna keep my b18c block and repair the dammage sleeve!!!
Old Aug 27, 2007 | 03:49 PM
did you crack a sleeve? if not just rebore, i have 82mm itr pistons for sale. Brand new still in box from RS Machines.
Old Aug 27, 2007 | 03:56 PM
DA_JDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">did you crack a sleeve? if not just rebore, i have 82mm itr pistons for sale. Brand new still in box from RS Machines.</TD></TR></TABLE>
The sleeve are not crack but all the pieces of my broken piston and the 4 valves mess up the surface of the sleeve...so my builder said he have to re-sleeve after inspection!!! Thanks for the offer of the pistons...i need 12:5 and up CR for my built!!!
Old Aug 28, 2007 | 04:53 AM
DA_JDM's Avatar
Old Aug 28, 2007 | 10:53 AM
kabaroo's Avatar
82mm is what im running this year. If something happens then im forced to re-sleeve! You can look at thats a good thing or bad...
Old Aug 28, 2007 | 03:49 PM
Cookie Cutter's Avatar
MY Cookie Cutter build is 82mm and it worked well.
Search under user Natural Aspirations
Old Aug 30, 2007 | 01:42 PM
DA_JDM's Avatar
Default Re: (Cookie Cutter)
...any more output???
Old Sep 2, 2007 | 12:40 PM
A1's Avatar
A1
Default Re: (DA_JDM)
im running 82/89 on gsr block.no problem at all.25+ run on dyno&gt;&gt;daily driven.
Old Sep 2, 2007 | 01:37 PM
NJIN BUILDR's Avatar
Default Re: (A1)
If you need to sleeve it then swap it with someone that has a std block that wants to sleeve theres.Save the 1k if you don't need the big bore or strength.
THEUSED
Aug 2, 2005 03:37 PM
clint g
Jul 8, 2005 05:42 AM
sky88
May 21, 2004 01:05 PM
5thgencivic
Nov 30, 2003 02:12 PM
b18cTurbo
Feb 9, 2003 08:23 PM
