help on sir headlight wiring
Old Aug 27, 2007 | 02:27 PM
PonoED's Avatar
Default help on sir headlight wiring
does anyone know how to hook up the wires from the SIR headlight to the usdm wiring?
the sir connection has 2 blue wires and one black.
help prefered from those who hooked up their zc headlamps and sir headlamp
or if u just know.
Modified by PonoED at 3:38 PM 8/27/2007
Old Aug 27, 2007 | 03:05 PM
Crx Jimmy's Avatar
Default Re: help on sir headlight wiring (PonoED)
It took me awhile but I figured it out you need 2, 5 prong automotive relays. Just read it and you should be able to figure it out
https://honda-tech.com/zerothread?id=1940594
Old Aug 27, 2007 | 03:20 PM
PonoED's Avatar
Default Re: help on sir headlight wiring (Crx Jimmy)
its sound correct man
and i think u are right on using relays and on how u are trying to say that once a high beam is on its just the highbeam and not the lowbeam @ the same time.
i thought that i could just connect everything w/o a relay but then it wud burn the bulb.
ill take a trip to autozone now lol
Old Aug 27, 2007 | 03:26 PM
PonoED's Avatar
but do u have a schematic? or picture?
Old Aug 27, 2007 | 03:30 PM
Crx Jimmy's Avatar
no just google an automotive relay and you will see how it works. I hooked it up the way I described and it works fine. Everyone on this forum said to just straight wire it but that would leave both filaments on and if you do a lot of high beam usage( I live in the sticks so sometimes its on for 1 hr. straight)it will burn the bulbs out super quick. If you have the h4h bulbs they are not cheap or easy to come by either. I actually got the euro sir(VTi) headlights that are glass and not plastic and have a motor to adjust the beam. They use regular H4 bulbs as well.
rockycat
Nov 20, 2017 03:28 PM
JohnnieChimpo
Apr 12, 2006 02:12 PM
Down Shift Motoring
Nov 18, 2005 08:17 AM
wu tang
Jan 16, 2005 09:33 PM
Crx Jimmy
Dec 14, 2004 05:01 PM
