help wheel hop like no budies bussiness
Old Jun 14, 2002 | 04:48 AM
spangler's Avatar
Default help wheel hop like no budies bussiness
as it says i have 98 lude 5 speed base
and everytime i launch whell hopp feels like the whole cars gonna fall apart
ive tried lauching at differnt rpms
im running 17 inch blitzs rims with kuhmos
its stock suspension but have teins on the way
anything else i can try to stop this
thanks
spangler
Old Jun 14, 2002 | 06:17 AM
GAperformance's Avatar
New User
Default Re: help wheel hop like no budies bussiness (spangler)
Try using the clutch to control the amount of power you put down on the launch. Don't just drop it, let it out to half way quickly and then all of the way out. Use the gas to control wheel spin. Also get adjustable shocks and if it continues try motor mount inserts. All of my wheel spin went away when I got AGX adjustables.
Old Jun 14, 2002 | 06:29 AM
kevie88's Avatar
Default Re: help wheel hop like no budies bussiness (bkw97lude)
Energy suspension motor bushings help a lot too, and they're pretty cheap.
Old Jun 14, 2002 | 07:37 AM
Prelude Vtec 23's Avatar
Default Re: help wheel hop like no budies bussiness (kevie88)
i use them and they helped
Old Jun 14, 2002 | 08:08 AM
TW00Si's Avatar
New User
Default Re: help wheel hop like no budies bussiness (Prelude Vtec 23)
The wheel hop is coming from too aggressive of a launch. You need to get grip first. Just ease off the gas and feather the clutch a bit. It's either your clutch going or your transmission because all the wheel hop isn't good for your motor. The suspension and motor mounts might help to reduce the wheel hop but initially don't launch too high. I've only gone to the drag strip with my prelude once and I found out that launching at 4k is ideal but you have to feather the clutch just a bit. I only got 3 runs that day due to rain. The fastest time was a 15.3 and the other two times I tried dumping the clutch and then the wheel was hopping like crazy, my air freshners even shot out of the vents into my friend's face...that was funny. Every run I had a passenger in my car. I don't care for drag races but I just wanted an idea what the car would do stock.
Old Jun 14, 2002 | 08:38 AM
illusion's Avatar
Default Re: help wheel hop like no budies bussiness (TW00Si)
what kind of idiotic track to you go to where they allow passengers?
Old Jun 16, 2002 | 07:55 AM
Buckkaaaa!!'s Avatar
New User
Default Re: help wheel hop like no budies bussiness (illusion)
wheep hop is like one of the worst things you can do to your car What I do that really reduces it is to ease into the beginning of the launch more..... In other words i slip the clutch just a tiny bit and get moving first while i still have the RPM. After I get moving then I start the full out launch. wheep hop is bad
edit: whoops i just read the others' posts and i guess others already responds with the same suggestions...my bad =P
[Modified by preludeboy, 8:56 AM 6/16/2002]
Old Jun 17, 2002 | 08:00 AM
TW00Si's Avatar
New User
Default Re: help wheel hop like no budies bussiness (preludeboy)
The idiotic track that I went to was Milan Dragway up in Michigan. Just a question though, why is it stupid to have a passenger in your car when you drag race? I mean, I understand that there's safety issues but my car isn't even in the 14s. I know for sure that they require helmets if you break into the 13s. On the safety issue, some clubs allow passengers at autox events...it's really preference...but I would like to know why you posted that. Thanks.
The Weather Man
Jan 22, 2006 10:07 PM
elitesi8
Oct 9, 2005 06:42 AM
Project_ED8
Mar 18, 2004 08:00 PM
HRDCORD
Dec 9, 2003 07:23 AM
ALF
May 18, 2002 09:29 AM
