harmonic balancer pulley....
Hello all! I'll get straight to the chase.... I'm having a hell of a hard time getting the freaking bolt off my harmonic balancer. I tried everything from using an impact wrench to brute force along with the pulley wrench(to keep it from spinning). I also tried 3 different lubricants(wd40, pb buster, forgot the other) It's been three days so far without any luck, and yes I'm moving the wrench in the right direction to loosen up the nut. Any suggestions you guys have to get this bolt off?
-Thanks,
Rich
-Thanks,
Rich
on my old motor it took one person held the pully wrench and the other person took there weight on the breaker bar with a extension on the breaker bar to make it longer and i guess you could say shock it you use all your wait and bounce up and down on it for a few minutes but also the person with the wrench better hold on tight!!!
welp get the moroso tool to help you out and then use a impact gun.. someone put lock tite on one of our b sereis that we were taking apart.. took our 750lb run to get it off.
MagicUnicorn
24
Apr 28, 2022 02:45 PM
fminusmic
Apr 27, 2018 02:52 AM
