5th gen ECU/taking it out???
Old Aug 27, 2007 | 12:30 PM
k_lude's Avatar
Default 5th gen ECU/taking it out???
would i just unbolt the two little bolts that you see when you lift up the carpet??or is there more?help very appreciated.
Old Aug 27, 2007 | 12:36 PM
117's Avatar
117
IIRC, there are 4 bolts that hold the ECU mounting plate in place, then you need to unbolt the ECU from the mounting plate to completely remove it. If you just want to remove the ECU from the car, unplug the ECU and remove it with the mounting plate.
miketunstall
Apr 3, 2017 10:43 AM
k_lude
Jan 3, 2007 02:53 PM
Dubs13
Oct 1, 2006 11:11 AM
sickofitall1113
Jun 13, 2005 11:21 AM
vbspec
Apr 8, 2004 03:56 PM
