SKUNK2 manifold... What FUEL RAIL do i use..
Old Aug 27, 2007 | 09:13 AM
central_driver's Avatar
Default SKUNK2 manifold... What FUEL RAIL do i use..
Notice how there is 3 screws from the manifold. My fuel rail only has 2 holes... + they dont even match up.
Here is a better look hopefully.. U can see they dont match up...
Now whats not pictured is... I can take the 2 screws off my old manifold and they do fit on this skunk2 manifold but... they are so close to those 3screws to the point where u cant even fit the fuel rail over it because it hits the 3screws
Ive seen some pics and it looks like the aem high flow fuel rail works... correct me if im wrong
Old Aug 27, 2007 | 11:51 AM
wilham320's Avatar
Default Re: SKUNK2 manifold... What FUEL RAIL do i use.. (central_driver)
the 3 studs are for an 0bd1 car, your y8/7 uses the two longer studs. Take the two studs out of your y8/7 manifold and put the in the skunk. take some vise grips and remove the 3 studs on the skunk, i believe i left mine in, but i have the aem rail. the aem rail would be a waste of money if you don't have 400+ hp, unless you really want it for the "bling". the only reason i have one is because it was free.
Old Aug 27, 2007 | 11:12 PM
Got a STR fuel rail for 15bucks.... Ummm. the fitting at the end is way too big so do i need an adaptor fitting or do i gotta buy a fuel pressure regulator
Old Aug 28, 2007 | 12:43 AM
nevermind fixed the problem. now i gotta fix my vaccum leak
xwhitchx
Mar 14, 2009 05:21 PM
central_driver
Aug 26, 2007 10:15 AM
KillerBee18
Jun 26, 2006 08:15 PM
zilverz
May 19, 2002 09:50 PM
