Do you get teeth grinding with Jun,Toda or Spoon flywheel with the ITR starter?
Old Jun 14, 2002 | 02:01 AM
bluesaint's Avatar
Default Do you get teeth grinding with Jun,Toda or Spoon flywheel with the ITR starter?
Im in the market to put a JUN ultra light chromoly flywheel in the ITR, but from i heard of issues where if u use Japanese flywheels u have to use a Japanese starter to avoid teeth grinding when starting the car, can anyone tell me the truth of this?
Old Jun 14, 2002 | 02:07 AM
ITR764's Avatar
Default Re: Do you get teeth grinding with Jun,Toda or Spoon flywheel with the ITR starter? (bluesaint)
i have a toda and no probs what so ever!
TODA=
Old Jun 14, 2002 | 04:45 AM
CRVRX's Avatar
Default Re: Do you get teeth grinding with Jun,Toda or Spoon flywheel with the ITR starter? (ITR764)
I have install all of those flywheels. Every JUN flywheel does grind at some point, some do it all the time and some every 10 hits of the key. I have never seen a Toda flyheel grind, I have put tons of them in too, Also never seen a Spoon either. I have a Toda Flywheel in my own car and it has never given me one problem.
Toda and Spoon=
Old Jun 14, 2002 | 04:51 AM
Mike K's Avatar
Default Re: Do you get teeth grinding with Jun,Toda or Spoon flywheel with the ITR starter? (CRVRX)
Comptech has never grinded in over a year.
Fidanza grinded the first two times I started the car after the new flywheel install, but hasn't done it since.
Clutchmasters never grinded.
Spoon is next to try, we'll see... just gotta burn my clutch up and I'll put this Spoon one in.
(these are only my personal accounts. yours may be different)
Old Jun 14, 2002 | 06:09 AM
YelLowITR's Avatar
i have JUN UL flywheel, and no problem at all...but i guess Toda's are lighter right?
Old Jun 14, 2002 | 06:25 AM
AssPenny's Avatar
Default Re: Do you get teeth grinding with Jun,Toda or Spoon flywheel with the ITR starter? (YelLowITR)
My spoon grinds like 50% of the time now. Some times if I just wait a second and try again it works. Sometimes I have to put the car in 5th and push it about an inch or so and then it works fine
Craig - Who is looking for an si/sir starter... anyone?
[Modified by AssPenny, 10:26 AM 6/14/2002]
Old Jun 14, 2002 | 07:00 AM
Black R's Avatar
25 Year Member
I installed my toda flywheel 500 miles ago. No problems period.
Mike, how was the comptech (6.75lb?) flywheel? How does it compare to say a 9lb one?
Old Jun 14, 2002 | 07:55 AM
ITR-01-0977's Avatar
New User
Default Re: Do you get teeth grinding with Jun,Toda or Spoon flywheel with the ITR starter? (Black R)
Toda
Old Jun 14, 2002 | 07:56 AM
Cheap Bastard's Avatar
New User
Jun
Old Jun 14, 2002 | 08:00 AM
FAST4DR's Avatar
Default Re: Do you get teeth grinding with Jun,Toda or Spoon flywheel with the ITR starter? (Cheap Bastard)
Toda is beveled and will not grind.
Old Jun 14, 2002 | 08:16 AM
ITR764's Avatar
i think the jun is lighter than the TODA, but because i have a TODA i think it's the best!!!
Old Jun 14, 2002 | 02:59 PM
bluesaint's Avatar
So seems like overall, the chances of grinding doesn't seem as often as with b16a folks.
seanb18c1
Feb 17, 2003 06:12 AM
dabomb
Sep 29, 2002 01:32 AM
quick108
Jul 15, 2002 02:12 PM
Isaac
Apr 3, 2002 01:48 PM
degradated
Jan 12, 2002 01:02 PM
