having problems with LC-1 please help!
Ok, so i hooked up my LC-1 wideband and i'm having big problems with it. First off it doesn't get burning hot like it's supposed to, it will barely burn my hand. The next problem is when i enter Crome Pro and hit the live tuning button it only shows that it's only putting out 3.8volts, whats up with that? Can anyone tell me whats going on, and let me know how to use the LC-1 with Crome Pro..
Thanks
Thanks
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda400ex »</TD></TR><TR><TD CLASS="quote">Ok, so i hooked up my LC-1 wideband and i'm having big problems with it. First off it doesn't get burning hot like it's supposed to, it will barely burn my hand. The next problem is when i enter Crome Pro and hit the live tuning button it only shows that it's only putting out 3.8volts, whats up with that? Can anyone tell me whats going on, and let me know how to use the LC-1 with Crome Pro..
Thanks</TD></TR></TABLE>
first off...why are you trying to burn yourself with it? put the sensor in the exhaust and before starting the engine do a free air calibration....see what values you get with logworks before you try using the analog outs.
read the directions, re-read the directions, double check your connections, and it should work fine. if you wire things wrong you can burn out your analog outs...and they wont work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrxsi90 »</TD></TR><TR><TD CLASS="quote">read the directions, re-read the directions, double check your connections, and it should work fine. <U>if you wire things wrong you can burn out your analog outs</U>...and they wont work.</TD></TR></TABLE>
x100
x100
