D-series stroker
Old Aug 25, 2007 | 08:53 PM
third lobe's Avatar
Default D-series stroker
has anyone done the D17 stroker for the D16 - I read up on it in a past Honda Tunning.
I am interested in working a project like this but I want to get some insight on it before I jump into it.
thanks in advance
-p
Old Aug 25, 2007 | 10:09 PM
Aquafina's Avatar
Default Re: D-series stroker (third lobe)
The article has about all the insight you need.
Old Aug 25, 2007 | 10:11 PM
third lobe's Avatar
Default Re: D-series stroker (Aquafina)
it has a ton of great info - I would want a bit more streetable motor(cant run it on race fuel all the time).
I am thinking of running D15B7 pistons in it to lower the compression.
If anyone can verify that compression ratio please let me know.
-p
Old Aug 25, 2007 | 10:14 PM
Aquafina's Avatar
D15B7 pistons would be out of the whole, and the valve reliefs would need to be enlarged if you're running anything other than a A6/B7 head. Just run the GX pistons. You can adjust your CR by how much you mill/deck, as well as HG, chamber work, valves, etc.
Old Aug 25, 2007 | 10:30 PM
third lobe's Avatar
your right maybe tossing the greddy 2mm HG will end up dropping it to where I want it.
-p
Old Aug 27, 2007 | 02:13 AM
pythoner's Avatar
or you just don't need to reweld the head and bring the CR up to 13:1 because of the head
gmacarize
14
Jul 18, 2007 07:13 PM
dumbshit
49
Aug 22, 2003 11:40 AM
MOTOR R
Nov 26, 2001 03:29 PM
OBD-One-Kanobe
Sep 17, 2001 02:54 PM
