whistling sound in engine
Old Aug 25, 2007 | 08:17 PM
aojtin's Avatar
Default whistling sound in engine
anyone notice wehn driving their crx a small noise that sounds almost like wind noise but you can tell it isnt from when you start to hear it like it may be louder if your in gear. I've heard a very faint one in mine and i just dont get whats making it
Old Aug 25, 2007 | 08:52 PM
garageEF's Avatar
Default Re: whistling sound in engine (aojtin)
alternator interfering with the sound system maybe?
Old Aug 25, 2007 | 09:26 PM
aojtin's Avatar
Default Re: whistling sound in engine (garageEF)
nah thats not it i had the stereo off while driving or DOESN'T that matter but thanks for the suggestion
Old Aug 25, 2007 | 09:37 PM
garageEF's Avatar
it doesnt matter if its on or off... is it like a whiring noise that matches your engine rpm?
Old Aug 25, 2007 | 10:53 PM
bobjohnson's Avatar
Yep that could be it. When i was younger, my moms stereo used to do the same thing in her tacoma. My dad put it in, and to be nice... well, he sucks at installing stereos. Try reving the car in your driveway and see if it still happens.
Its because something along the way isnt grounded. Quickest, easiest fix is to take the ground from the deck and put it to the frame instead of using the ground in the wiring harness. I ground mine to the bolts under the center console (by the shifter).
If it only happens when youre moving, might be your transmission.
Old Aug 27, 2007 | 02:44 PM
aojtin's Avatar
Default Re: whistling sound in engine (bobjohnson)
yeah it does only when im moving so i was kinda thinking the tranny i hope dont have to replace it in the near future
Old Aug 27, 2007 | 03:04 PM
wiZCo's Avatar
Stouts 'n' Scotch
Do you have an aftermarket intake? I've noticed a small whistling noise with some if they aren't on 100% straight.
Try revving the engine in neutral to see if it makes the noise.
Old Aug 27, 2007 | 03:12 PM
89hatcher's Avatar
its probabaly a intake...but also if you have a stereo amp your RCA and power wire are close together you should route it opposite from each other meaning power wire on your driver side and RCA passenger side.
Old Aug 28, 2007 | 07:24 AM
aojtin's Avatar
everything is stock like factory stock original intake and stereo
Old Aug 28, 2007 | 08:26 AM
jdm_titan's Avatar
it could be an exhaust leak, vacum leak, and let's hope it's not ur flywheel!!!
Old Aug 28, 2007 | 09:14 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (aojtin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aojtin &raquo;</TD></TR><TR><TD CLASS="quote">everything is stock like factory stock original intake and stereo</TD></TR></TABLE>
Have you checked if it makes the noise when you rev it at idle?
Old Aug 28, 2007 | 01:03 PM
aojtin's Avatar
Default Re: (wiZCo)
yeah it doesnt it only makes the wistling sound when im moving
1994PreludeSi
Dec 19, 2007 07:58 AM
Silvteg95
Aug 1, 2005 11:28 AM
redliner8000
Feb 19, 2004 08:49 PM
obsidianG35
Sep 4, 2003 08:55 AM
