A Type S with an opinion needed!
Old Aug 25, 2007 | 04:49 PM
concept11253's Avatar
Default A Type S with an opinion needed!
I bought the rays extended lugs for the itr wheels and waited like 2 months for them. Problem is that they look out of place to me and I am not really sure that I like them. What do you guys think?
Old Aug 25, 2007 | 04:52 PM
bmoua's Avatar
it looks decent...
i would of gone with black lugs...
Old Aug 25, 2007 | 04:53 PM
LSTeger's Avatar
Looks good, I think...
Old Aug 25, 2007 | 04:59 PM
tenedor sports's Avatar
Default Re: A Type S with an opinion needed! (concept11253)
white on white
Old Aug 25, 2007 | 05:01 PM
BLANCOh22a4's Avatar
i like em...as long as they are the correct lugs
Old Aug 25, 2007 | 05:04 PM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by concept11253 &raquo;</TD></TR><TR><TD CLASS="quote">I bought the rays extended lugs for the itr wheels and waited like 2 months for them. Problem is that they look out of place to me and I am not really sure that I like them. What do you guys think? </TD></TR></TABLE>
Looks like poop
All the guys that do this seem to forget that the USDM white = NOT jdm white...
hence it looking ghetto.
and you're hood looks warped.
Old Aug 25, 2007 | 05:12 PM
crapanese's Avatar
i think they look good man. nice car.
Old Aug 25, 2007 | 06:30 PM
Thanks guys. They are the correct lugs, 12x1.5. I think I am gonna go with shorter ones though as I should have in the first place. I was just too lazy to change out my wheel studs because I have the extended studs and want shorter studs.
Old Aug 25, 2007 | 06:34 PM
RARE_EG2's Avatar
it looks good, and would look better if you get a lip kit on the car
Old Aug 25, 2007 | 06:37 PM
DSEA2's Avatar
Default Re: (concept11253)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by concept11253 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys. They are the correct lugs, 12x1.5. I think I am gonna go with shorter ones though as I should have in the first place. I was just too lazy to change out my wheel studs because I have the extended studs and want shorter studs.</TD></TR></TABLE>
i believe hea is talking about using "tuner" lugs on oem wheels. they do not seat right.
Old Aug 25, 2007 | 06:41 PM
HondamanXxX's Avatar
GO GIANTS!
Default Re: (SpoonDC4)
Looking good dude.
Old Aug 25, 2007 | 07:05 PM
Default Re: (solbrothers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers &raquo;</TD></TR><TR><TD CLASS="quote">
no, the lug nuts may be the wrong shank (idk if that's the correct term)</TD></TR></TABLE>
Oh yeah they are technically the wrong style nut. You need the style with a flat bottom and these have a point. I should be running oem wheel lugs with these oem wheels. I heard that if you run the wrong style lugs, your lug nuts will come loose easier. But I keep my torque wrench in the car so I think I am good to go.
Old Aug 25, 2007 | 07:06 PM
omg_miiiike's Avatar
This was your reason to ***** your car !
JK, I think they look good ..
Old Aug 25, 2007 | 08:14 PM
HcOiNvDiAc's Avatar
Default Re: (omg_miiiike)
i like it
Old Aug 25, 2007 | 08:18 PM
Leo C's Avatar
Night Owl
Nice car but mismatching lug types is a terrible idea.
What might happen? You're reducing the contact area that the lug has on the wheel, increasing its chances to loosen or even possibly crack a rotor. The only place that the lugs are touching the wheels is along a circle, rather the the entire surface area of the lug.
It's very possible for them to work themselves loose when they don't come into contact along the entire surface area of the wheel. You might get lucky and notice that the wheel is wobbly and be able to re-torque them before they bend and snap a stud or two. Or maybe not, and a wheel could come loose. Either way, you're dramatically increasing the likelihood of causing hundreds of dollars of damage to that beautiful RSX.
Straight from the wheel/tire faq if you don't believe me (I worked as a wheel/ tire tech for years). Yes I have re-torqued tuner lugs that were literally finger loose on OEM wheels.
"The "seating area" (or "seat") is the area of the lug nut, and the area of the wheel, that come in contact with each other. Stock Honda/Acura wheels have a ball/radius/spherical shaped seating area, and need lug nuts (such as stock lug nuts) which also have the same shaped seat. Aftermarket wheels use a tapered/conical/cone shaped seating area and need lug nuts (including most tuner lug nuts) which also have the same shaped seat. No, it is not safe to mix and match (stock wheel with tapered lugs or vice versa); the contact between the lugnut and the wheel will be insufficient, putting undue stress on them and potentially causing failure."
Old Aug 25, 2007 | 08:21 PM
Default Re: (Leo C.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leo C. &raquo;</TD></TR><TR><TD CLASS="quote">Nice car but mismatching lug types is a terrible idea.
hmmm... thanks for that. That made my mind up. lol. They are coming off. Anyone interested.
Old Aug 25, 2007 | 08:24 PM
Leo C's Avatar
Night Owl
Just FYI, you can buy red or other colored 12x1.5 lugs on ebay for about 30-40 a set.
I'm too lazy and drunk to search for em atm though
Old Aug 25, 2007 | 10:54 PM
EFSedan#6's Avatar
Car looks good, yes, lugs look goofy that far out there.
Old Aug 25, 2007 | 11:23 PM
Markland Photo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by concept11253 &raquo;</TD></TR><TR><TD CLASS="quote"> I am not really sure that I like them. </TD></TR></TABLE>
screw teh lug nuts, the wheels look hot fiyaaaa
edit: front lip ftw
Old Aug 26, 2007 | 12:37 AM
Uncle_Ben's Avatar
Default Re: A Type S with an opinion needed! (bulletspastsunset)
Those lugs look way better on an aftermarket wheel that has a deep hub so they don't stick out past the wheel. When they come right out to the edge of the hub they look straight
Old Aug 26, 2007 | 02:08 AM
Doostur's Avatar
Clean! looks good. Love the white.
Old Aug 26, 2007 | 02:53 AM
__oversea's Avatar
yeah...having tprque wrench is not gonna cut it.
i never seen ITR wheels with extended lugs. i see why
Old Aug 26, 2007 | 06:06 AM
DC4KiD's Avatar
Default Re: (RARE_EG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RARE_EG2 &raquo;</TD></TR><TR><TD CLASS="quote">it looks good, and would look better if you get a lip kit on the car </TD></TR></TABLE>
i agree.
Old Aug 26, 2007 | 10:45 AM
neeks's Avatar
i think it looks
what other options were you looking into?
and where did you relocate your temperature controls too?
Old Aug 26, 2007 | 12:01 PM
Mrs. Triscuit's Avatar
Default Re: (bmoua)
The type-r rims are not meant to be used with after market lugs, so it looks out of place and not safe (dont seat well with rims meant for oem lug nuts).
