Hondata
Old Aug 25, 2007 | 02:22 PM
95dxsir2's Avatar
Default Hondata
1.Is it worth buying a used hondata s200 setup without the boost option if i'm going to be running boost?
2.would i be better off running chrome?
3.Could it possible to send in the s200 unit & get it upgraded to the boost option?
posted this in tech/misc also. Just want a good amount of feed back in the time frame of 3 hours
Old Aug 25, 2007 | 02:27 PM
ej1sir16's Avatar
it would be cheaper to get chrome but hondata is much better to do it right the first time, and hondata offers alot of things, you can check there site it is very helpful, i think you just buy extra things with the s200 to run boost, but i would check hondata.com for more info, they have a forum to, i learne alot of stuff on there
Old Aug 25, 2007 | 02:33 PM
95dxsir2's Avatar
Default Re: (ej1sir16)
<U>Various additional options are available, either when the unit is ordered or as an upgrade later:</U>
Price Description
$50 3 step rev limiter- Launch control and full throttle shift. (optional upgrade on systems purchased before 3/1/05)
$200 Boost capability. Needed for turbo or supercharged applications
$50 Datalogging capability. Required if you want to tune it yourself (optional upgrade on systems purchased before 12/13/04)
Discontinued G Sensor module.
$200 ROM Editor. Required for tuning yourself.
$180 Romulator realtime emulator.
$180 Programmer (requires ROM Editor) Required for tuning yourself
I must be to stoned to read closely.....thanks for the reply
95dxsir2
Aug 25, 2007 02:37 PM
Prudz_lude
May 29, 2007 07:01 AM
DaX
Jul 18, 2005 06:19 AM
