ARP cam cap bolts?
I've only seen arp STUDS not bolts for cam caps on neon heads and a few other domestic engines. You better be sure to at the least plastigauge the cams if you do end up finding a way to install some studs. You will want to check and make sure that it doesn't distort the cam bores like the main studs do. You may be looking at align honing the caps.
IMHO get new bolts from honda if it really worries you.
