2002 Accord Automatic
Old Aug 25, 2007 | 12:09 PM
rjones17's Avatar
Default 2002 Accord Automatic Transmission Problem
Hi Guys,
The transmission on my 2002 Accord started acting wierd last week. When I come to a stop there is a hard downshift. When I start off, say from a red light, the tach moves quickly to 2500 -3000 and it shifts hard again. The car has 110,000 easy miles.
The check engine light is on and the green light around D4 is blinking.
I took it to a dealer this morning and they want $3k for a new transmission.
Thoughts? Ideas? Suggestions?
Modified by rjones17 at 1:30 PM 8/25/2007
Old Aug 25, 2007 | 03:28 PM
01_CLtypeS's Avatar
Default Re: 2002 Accord Automatic Transmission Problem (rjones17)
wait until your trial period expires and look here--> http://www.hondamarketplace.com/zeromain
for a used tranny...
Old Aug 26, 2007 | 05:59 AM
H2290's Avatar
How many miles on the car? The tranny warranty on pretty much all of these auto Accords has been extended to 100K miles due to constant problems. You should call Honda of America and give them your VIN and they should authorize a no charge replacement.
Old Aug 26, 2007 | 12:32 PM
361 accord's Avatar
Default Re: 2002 Accord Automatic Transmission Problem (H2290)
damn that sucks, and the warranty is actually 109K or 7years+9mos.
Old Aug 27, 2007 | 12:26 AM
ngfriend's Avatar
Default Re: 2002 Accord Automatic Transmission Problem (361 accord)
I had a similar problem for my 2000 accord sedan and I changed my transmission oil if you haven't done so within the last 20-30k miles. I suggest you purchase Honda transmission oil (ATF) 5 quarts. Aproximately $35 and $50-70 labor at a local mechanic. I took it to my mechanic and changed the transmission oil and it jerks a little when I shift, but not as significant as it did before. Eventually you'll probably have to rebuild it or do a tranny swap.
Old Sep 1, 2007 | 11:09 AM
jellems's Avatar
You can also try to put some Lucas NO SLIP transmission oil to stop it from shifting hard. I had a similar problem in a mitsu eclipse 91 , and it actually fixed the problem in that car and the cars been running a good 27,000 miles since i put it in.
Old Sep 1, 2007 | 11:41 AM
accordselux's Avatar
Me Gusta History
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjones17 &raquo;</TD></TR><TR><TD CLASS="quote">Hi Guys,
Modified by rjones17 at 1:30 PM 8/25/2007</TD></TR></TABLE>
When my Accord did that I got a new tranny under warranty. 98-02 Autos are terrible.
Old Sep 1, 2007 | 04:31 PM
ReDhotAccord's Avatar
yea the check engine light only has to do with your emu's cause i have a 98 an mine came on an it just was my cadalidic converter an i needed a new emu emissions valve, but it could be that you didnt tighten you gas cap more than three clicks, as for you trans. i have no idea.
Old Sep 1, 2007 | 04:41 PM
someone else's Avatar
It Wasn't Me!
Default Re: 2002 Accord Automatic Transmission Problem (ReDhotAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDhotAccord &raquo;</TD></TR><TR><TD CLASS="quote">yea the check engine light only has to do with your emu's cause i have a 98 an mine came on an it just was my cadalidic converter an i needed a new emu emissions valve, but it could be that you didnt tighten you gas cap more than three clicks, as for you trans. i have no idea.</TD></TR></TABLE>
This post is gibberish and should be deleted. The CEL can and will come on for transmission problems as well as emissions and other drivetrain issues.
The 98-02 transmissions definitely have issues but most 02's are not covered under the warranty extension. Unless some dealer takes pity on you and goodwills it the only other possibility of getting someone to pay for it would be to contact American Honda customer service and ask for help.
Old Sep 8, 2007 | 04:26 PM
PRNDL's Avatar
Default Re: 2002 Accord Automatic Transmission Problem (ngfriend)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2290 &raquo;</TD></TR><TR><TD CLASS="quote">How many miles on the car? The tranny warranty on pretty much all of these auto Accords has been extended to 100K miles due to constant problems. You should call Honda of America and give them your VIN and they should authorize a no charge replacement.</TD></TR></TABLE>
Where did you get this information?
My mothers 2000 Accord V-6 transmission just quit with only 16000 miles on it.
It will be 8 yrs old in November so I need to know where you got your information please.
Old Sep 15, 2007 | 05:18 AM
H2290's Avatar
Default Re: 2002 Accord Automatic Transmission Problem (PRNDL)
From Honda of America. Just give them a call and find out.
Dizzyman
Apr 11, 2013 08:10 AM
Pdavis53
May 23, 2011 09:48 PM
creator1322
Aug 22, 2008 12:57 PM
jjyellow
Jun 8, 2007 07:17 AM
nfiniti
Nov 14, 2006 12:14 PM
