12.5 CR...................
Old Aug 25, 2007 | 11:46 AM
HI_Si's Avatar
Default 12.5 CR...................
I am looking into getting a pair of Buddy Club SPEC lll cams so i went to the Buddy Club website to do my research and they suggested that i bump my CR to 12.5 . sounds a little excessive since they suggest the same CR for their SPEC lV, V and Vl cams. does anyone have these cams in their GSR or B16? what results did you get? any info is greatly appreciated. thanks alot
Old Aug 25, 2007 | 11:51 AM
t0p_sh0tta's Avatar
Default Re: 12.5 CR................... (HI_Si)
If you're going with an aggressive cam, you should raise your compression. If you choose not to, you're just waisting money.
Old Aug 25, 2007 | 11:57 AM
cartune network's Avatar
buddy club spec 3's are fine without swapping the pistons out or bumping up your comp ratio. in a stock gsr i saw a huge gain of about 20hp over ctr cams. i wouldnt run anything larger than bc3's on the stock bottom end cause to really take advantage of the cams u will need a higher comp ratio. but for buddy club 3's u just need springs and some retainers.
Old Aug 25, 2007 | 12:04 PM
HI_Si's Avatar
Default Re: 12.5 CR................... (cartune network)
would i be able to go bigger than bc3s with a 98 spec ITR?
Old Aug 25, 2007 | 12:20 PM
ur gonna loose power if u go with anything bigger because u dont have a high enough compression ratio to take advantage of the larger cams. bc3's are perfect for a 98 spec itr thats what i have them in. your going to need a tune though.
Old Aug 25, 2007 | 02:54 PM
doood's Avatar
been there done that
bc3's arent a very big cam. they can work with anything from stock compression to 12:1+.
Old Aug 25, 2007 | 03:15 PM
Default Re: 12.5 CR................... (doood)
yes but the buddy club 4's wont work well with a stock compression. and buddy club 3's are larger than ctr's
cdfran
May 19, 2008 07:13 AM
phantom_sol
Jul 7, 2004 10:00 AM
MugenB18cTeC
Jun 11, 2004 09:02 AM
redman223
Dec 28, 2003 01:48 AM
VTEC-DA
Mar 7, 2003 12:14 PM
