normal for a newly installed clutch to slip a bit??
Old Aug 25, 2007 | 09:14 AM
an2ny888's Avatar
Default normal for a newly installed clutch to slip a bit??
i'm in the process of breaking in my clutch ( oem itr pp and cd, exedy flywheel ), right now i only have 100 miles on it. i was in the carpark the other day, puttering along in first gear when i gave it some gas ( so i could hear my exhaust ), i heard the engine rpm's going up but the car didn't move for a moment, is it normal for a new clutch to slip a bit before it breaks in? i can also hear a sort of whirring sound from the clutch when i'm slipping it a bit when i have to go up an incline
Old Aug 25, 2007 | 09:17 AM
Doostur's Avatar
Houston we have a problem. How severe is the slipping? Reguardless I have never had a new clutch slip at all. I am no expert in that area though by any means.
Old Aug 25, 2007 | 10:01 AM
snapcase318's Avatar
Default Re: normal for a newly installed clutch to slip a bit?? (an2ny888)
Did you replace the main seal? Sounds like it's leaking onto the clutch
Old Aug 25, 2007 | 12:31 PM
ithrowpoop's Avatar
Default Re: normal for a newly installed clutch to slip a bit?? (snapcase318)
try adjusting the push rod on the clutch pedal. it sounds like it might not be realeasing all the way. it is a common problem when intalling an exedy clutch. i know you put in a stock one, but it might help.
Old Aug 25, 2007 | 02:00 PM
oneup's Avatar
Default Re: normal for a newly installed clutch to slip a bit?? (ithrowpoop)
Don't you have to break in the clutch to around 300 miles?
Old Aug 25, 2007 | 03:11 PM
ITR184's Avatar
Doesn't seem right. How hard did you get on it? You have material on the clutch disc that beds into the pp and the flywheel. Just like brake pads on rotors. It shouldn't slip enough for you to notice though. Did you tork down the pp bolts correctly?
DC5KING
42
Feb 22, 2017 08:31 AM
neopheus
Mar 13, 2005 10:20 PM
Flexer
Apr 16, 2004 07:43 AM
Beave0101
Mar 23, 2003 08:36 AM
Accord_Munch
Dec 17, 2001 12:33 PM
