JRSC and CRV crank pulley gain PSI ?
Old Aug 25, 2007 | 08:47 AM
JDC2TypeR's Avatar
Default JRSC and CRV crank pulley gain PSI ?
I heard that by replacing the B18 Crank pulley to the CRV B20 crank pulley and you will boost 10 PSI instead of the stock boost that comes with the JRSC which is 8 PSI i'm not sure???any info will be appreciated. thanks
Old Sep 14, 2007 | 12:04 PM
Amped's Avatar
Default Re: JRSC and CRV crank pulley gain PSI ? (JDC2TypeR)
Check this out
http://ftlracing.com/tech/honda/jrsc_pulley.html
Old Sep 14, 2007 | 12:56 PM
i-VTEC_do_you's Avatar
ya my buddy had a b20 with type r head with JRSC and some tuning, he was able to get a 15psi spike while tuning, so they limited it to 9psi
Old Sep 14, 2007 | 06:46 PM
sc4dr's Avatar
Default Re: JRSC and CRV crank pulley gain PSI ? (i-VTEC_do_you)
That doesn't add up. eaton blowers don't spike. A b20 crank pulley, and stock alt. and blower pulleys will give you around 8-9 psi. If he had aftermarket cams, or really poor cam timing it could create useless overboost.
klungemonger
Nov 8, 2006 09:12 AM
ITR-965
Jul 15, 2006 02:56 PM
Average Al
Aug 25, 2005 01:58 AM
