HELP PLS - Did timing belt - now engine is not smooth at idle/under power
Old Aug 25, 2007 | 08:11 AM
tacorican's Avatar
Default HELP PLS - Did timing belt - now engine is not smooth at idle/under power
Hi, I am new to this forum. I have been reading and did my searches and am sure this has probably been discussed somewhere but I couldn't find it. I have a 2001 Honda Accord EX 4CYL that I changed the timing belt myself about a month ago, now my engine has a few problems specified below.
* At idle, I notice a vibration coming from the engine. Its on and off/comes and goes. Feels like the idle was too low at times. I thought it was the TPS but its not. If I rev a bit, the vibration goes away.
* When driving, I noticed if I pree the clutch (Sometimes I let the car coast as I approach a drive way) the car dies and of course when I let clutch go again engine keeps going again. (This only happens sometimes but when it doesnt happen, it shoud feels like it wants to die).
* Car is UNDER Power from take off to maybe 2500RPM then it feels normal.
Me and my co-worker who does work on cars all the time thinks that Timing is off. I know for a fact that one of the lines on one of the pulleys where the balancer belt goes was not alligned, but because I could not put the belt without that staying right where I left it. What does the balancer belt do? From looking at the Crankshaft Pulley and Timing gear now, they all line up fine. I am just trying to make sure if its the timing then I will take the time to redo it. Has anyone on the forum had this problem? I am just trying to make sure I don't take all that apart to find out it was something very simple.
Thank you!
lothian
Jan 30, 2018 06:12 AM
Meraut
May 8, 2013 09:43 AM
ShinobiLude
Nov 8, 2006 08:40 AM
llevity
Jul 12, 2005 02:39 PM
curiousgpnoy
Jan 20, 2004 11:16 AM
