crower stage 1
Old Aug 25, 2007 | 07:56 AM
girliehonda's Avatar
Default crower stage 1
what are your views and experiences using crower stage 1 on you NA setup?
good power gain or no?
also compare with skunk2 stage 1 and ctr?
and last question could the crower be use on stock valvetrain? thanks
Old Aug 25, 2007 | 08:00 AM
cartune network's Avatar
Default Re: crower stage 1 (girliehonda)
what are the specs on the cams? what head r u using? what is the mileage?
i personally dont like to run larger aftermarket cams on stock valvetrain but if u go with aftermarket springs i would get ones that are rated accordingly for the cam setup. too stiff of a spring isnt that good cause ull have some serious valve lash.
Old Aug 25, 2007 | 08:06 AM
Default Re: crower stage 1 (cartune network)
stock gsr and new stock valvetrain.
dont ask me why stock valvetrain because i bought the head like this and the last owner got the receipt dating which is last months.
Old Aug 25, 2007 | 08:11 AM
get a set of type-r valve springs and u should be good for the crower stage 1's. for the skunk2 stage 1's i would changethe valve springs. but if ur looking into skunk2 pro series i would change the springs and retainers.
Old Aug 25, 2007 | 08:13 AM
alphaq69's Avatar
ctr cams you will see amazing gains.. not to mention vtec coming on alot harder.
crower stg 1s should be fine with stock valvetrain as long as you dont go pass the stock rev limiter. the gains between the two should be similar.
i had a stock b20vtec with ctr cams/short ram intake/2' exhaust. and i pulled 175whp untuned running on an b18 program. 20whp jump at vtec.
Old Aug 25, 2007 | 09:10 AM
IntegraType-R's Avatar
Default Re: crower stage 1 (alphaq69)
Crower 1's are just a tiny big bigger then ctr/itr's, the s2s1's are a tiny bit bigger then the crower 1's.. personaly for the money you spend you could go with a itr valvetrain and ctr cams instead of wasting money on a cam thats not worth it, a stage 1 cam isn't all that different from a ctr.
DC2_2
May 17, 2008 07:29 AM
RiSiNgDc2
Mar 9, 2006 03:53 PM
j_quan
May 4, 2005 09:35 AM
thehondaguru
Sep 25, 2003 07:07 AM
ActiveAero
Jul 12, 2003 08:29 AM
