gsr brake swap
whats up honda tech i searched for thsi and really didnt fidn what im lookin for i got the rear hubs and the front of a 99 gsr now my question is can i use the gsr brake booster? or do i need to find another one, and is everthign bolt on or do i have to get some other parts thank you.
oh ok thats cool casue i was readign about soemthing that my pedal would feel soft, now what about the e brake cables can i use my stock ones or do i have to get new ones, and the prov valve? stock,1992 civic si, or gsr witch one
take the cable from the gsr...its a btich to put in if it doesn't have one. you should use a brake booster from a teg to use the brakes to their full potential. also get a prop valve from a rear disk setup..i think any rear disk prop valve werks
yea i got the booster but does it bolt right in and i think the cables are cut can i use another set from soemthing differant or it has to be a teg? thanks for everyones help.
yeah im having the same problem as this guy i got a 94 hatch and i got b16 brakes on the front and im puttin gsr disks on the back and i need to know if i should put a gsr master cylinder and prop valve on it.. bc im hearing diff things every where i go.
djrico724
Suspension & Brakes
Jun 3, 2008 04:22 PM
I just did a rear disc brake swap, Do I need the brake booster and master cylinder from a 4 disc bra
Sinner
Apr 12, 2004 07:00 PM
Yellow Dragon
Jun 7, 2001 08:15 PM
