Man i need help, i need my car fixed by monday!!!
Old Aug 24, 2007 | 08:18 PM
RA61825's Avatar
Default Man i need help, i need my car fixed by monday!!!
Alright guys i need some help. My car (1990 civic ex Auto) is acting weird on me. WEll it starts up sometimes the car runs, but say i turn it off and try to turn it back on it doesnt want to start. Ive check my distributor, i replaced it about a year ago and nothing. Well after a while it didnt want to turn on at all, so my girls dad gave me a jump start with his truck and it turned on right away. So it seems like jump starting it starts it right up. Sometimes it shuts down after a while of being on. I need some help guys
Update: WEll i checked the cables and all is good. Let me just clarify my situation. So basically the car wont turn over with out a jump start. If theres no jump start the car will just be strugging to turn.
Modified by RACERX72 at 9:14 AM 8/25/2007
Old Aug 24, 2007 | 08:34 PM
crxcess's Avatar
Default Re: Man i need help, i need my car fixed by monday!!! (RACERX72)
I'm pretty sure its your batery terminals or another ground issue. I had the same problem with 2 other cars. clean the terminals and make sure the connections are tight.
Old Aug 24, 2007 | 08:36 PM
RA61825's Avatar
damn ill try that buddy, any more help would be appreciated
Old Aug 24, 2007 | 08:47 PM
RA61825's Avatar
bump
Old Aug 24, 2007 | 09:28 PM
placid888's Avatar
it could be the alternator or weak battery, need more information
Old Aug 24, 2007 | 09:32 PM
garageEF's Avatar
Default Re: Man i need help, i need my car fixed by monday!!! (placid888)
search "main relay" and make sure you click "archives". that will tell you how to fix your problem.
Old Aug 24, 2007 | 10:37 PM
Foxcow's Avatar
I had a similar problem. My car would not reliably start but it turns out that the battery was the culprit. Make sure the terminals are corrosion free and put some vasaline on them to prevent future corrosion.
Old Aug 25, 2007 | 08:04 AM
RA61825's Avatar
man its not the wires guys
Old Aug 25, 2007 | 08:05 AM
RA61825's Avatar
I had the battery checked
Old Aug 25, 2007 | 08:27 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACERX72 &raquo;</TD></TR><TR><TD CLASS="quote">I had the battery checked</TD></TR></TABLE>
What about the alternator? Autozone will check them for you.
Hamstr323's Avatar
main relay?
Old Aug 25, 2007 | 09:39 AM
Aristotle's Avatar
Alternator for sure.
Old Aug 25, 2007 | 02:52 PM
spaceman's Avatar
i had problems like that and it turned out to be the positive cable that goes from the starter to the main fusebox had some bad connections.
good luck
Old Aug 25, 2007 | 02:57 PM
Hamstr323's Avatar
Default Re: (Aristotle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aristotle &raquo;</TD></TR><TR><TD CLASS="quote">Alternator for sure. </TD></TR></TABLE>
very good way to check this leave the battery term loose jump start the car and pull one of the terminals from batt if car dies then alt is the problem
civic efb16
Aug 6, 2005 07:52 PM
gaydm.accord
Mar 30, 2005 06:20 PM
moleodonuts
Aug 6, 2004 11:21 PM
Ideal
Nov 6, 2002 09:47 AM
awall
May 16, 2002 10:37 AM
