Cooling system PSI??
Old Aug 24, 2007 | 04:17 PM
De_tour's Avatar
Default Cooling system PSI??
Modified by De_tour at 6:08 AM 8/30/2008
Old Aug 25, 2007 | 06:48 AM
De_tour's Avatar
Default Re: Cooling system PSI?? (De_tour)
up
Old Aug 25, 2007 | 06:32 PM
De_tour's Avatar
bump
Old Aug 25, 2007 | 07:19 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by De_tour &raquo;</TD></TR><TR><TD CLASS="quote">What would the PSI be for the 92-95 civic half size radiator.
I bought a radiator cap thats for the LS which is 16lbs, if i use it will i be fine?
I just looked at the helms.
OEM for '92-'95 half-rads is 13.5-17.8 PSI.
So yeah, if it's 16lbs that should work peachy.
Old Aug 25, 2007 | 07:21 PM
imaricernamedrossthull's Avatar
Default Re: Cooling system PSI?? (Syndacate)
syndacate you're a ******* idiot i've seen you're posts get a life ***
Old Aug 25, 2007 | 07:35 PM
Syndacate's Avatar
Default Re: Cooling system PSI?? (imaricernamedrossthull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imaricernamedrossthull &raquo;</TD></TR><TR><TD CLASS="quote">syndacate you're a ******* idiot i've seen you're posts get a life ***</TD></TR></TABLE>
Are you pissed off at me because I can read the helms manual?
The whole "literacy" thing getting to ya?
EDIT:
1) "syndacate" should be "Syndacate" as you are reporting a name - though it be a handle - not a word.
2) Only the word "****" is censored on H-T - there is no need for blank tags in "*******."
3) Don't mix up "you're" and "your" - it should be "I've seen your posts."
4) "I" is capitalized.
5) Should be a comma after "life."
6) Should be a period after "***."
7) Should be a comma after "idiot."
8) Should be a comma after "posts."
That's just one sentence...
Old Aug 25, 2007 | 08:06 PM
97Ej6mike's Avatar
Proof or ban
reported
Old Aug 25, 2007 | 08:11 PM
Syndacate's Avatar
Default Re: Cooling system PSI?? (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">
Proof or ban
reported </TD></TR></TABLE>
Oh there's plenty of proof that I'm an idiot. I'm no *** though.
Though I was just reading it straight out of the Helms. For once it's information that CAN'T be argued about...
I don't know man....just dunno .
HT Chaplain
Welding / Fabrication
12
Dec 1, 2007 04:13 PM
OUT_OF_ORDER_DB7
Northern California (Sales)
Oct 4, 2007 07:12 AM
VTECsound
14
Oct 5, 2005 09:56 AM
B16CRXT
Feb 2, 2005 05:49 PM
upi95civic
Aug 23, 2004 09:29 PM
