Which ITR guy is it that is always buying the O2 wire harnesses / selling simulators?
Old Aug 24, 2007 | 01:46 PM
MOVE OVER's Avatar
Default Which ITR guy is it that is always buying the O2 wire harnesses / selling simulators?
I don't recall who it is, but someone has in their sig that they buy oxygen sensors to make simulators out of.
I don't remember who it is, but I would like to contact them.
I am in need of a simulator and figured they would be the first person to contact.
Any ideas?
I do know that it is someone who has posted a lot and been around a long time.
Old Aug 24, 2007 | 01:52 PM
vtec.dc2's Avatar
Default Re: Which ITR guy is it that is always buying the O2 wire harnesses / selling simulators? (MOVE OVER
i would go with.. aisle 8.. local supermarket.. aluminum foil.. if that doesn't work or work long enough then try ebay, and you can keep sensor on the inside, no need to ziptie it underneath..
i've seen them on ebay too for like 40-50, just need the right keyword
it was either ebay or yahoo search where i found someone selling them.
Old Aug 24, 2007 | 01:55 PM
RStoR's Avatar
Black R
Old Aug 24, 2007 | 02:06 PM
MOVE OVER's Avatar
Ah. yes, it is black R, than you.
I did the foil trick, but it only worked for about a month and a half.
Old Aug 24, 2007 | 03:35 PM
Comp97GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MOVE OVER &raquo;</TD></TR><TR><TD CLASS="quote">
I did the foil trick, but it only worked for about a month and a half.</TD></TR></TABLE>
Score another point for me.
John 9 &gt; Kevin 3
Old Aug 24, 2007 | 04:45 PM
MOVE OVER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">
John 9 &gt; Kevin 3</TD></TR></TABLE>
I almost want to say it is Jeff's ecu.
It ran fine the entire time I used his ecu. I have put only 45 miles on the car since I put in the new ECU that I bought and now I have the problem.... I think Jeff got lucky with a fluke ECU
Old Aug 24, 2007 | 07:26 PM
DontBlink's Avatar
this has always worked for me, and if it dont for some odd reason you only wasted $4.99
http://www.ephatch.com/resourc...g.htm
Old Aug 25, 2007 | 10:40 AM
BudMan's Avatar
It ran fine the entire time I used his ecu. I have put only 45 miles on the car since I put in the new ECU that I bought and now I have the problem.... I think Jeff got lucky with a fluke ECU </TD></TR></TABLE>
I used to have the problem all the time with that ecu...until I did the foil trick.
It must be the installer j/k
Your car baffles me
Old Aug 25, 2007 | 11:56 AM
Black R's Avatar
25 Year Member
yeah, it's me.
i've made a few for uncleben, etc..... ask him how he likes it.
Old Aug 27, 2007 | 04:25 PM
Black R's Avatar
25 Year Member
dang, I'm popular:
https://honda-tech.com/zerothread?id=2075949
sensor can be left in the cat or test pipe. but i recommend you pull it into the car and tuck it behind the stereo console. that way it'll last forever and never throw a code.
but i call them 'foolers' since they don't replace the 2ndary o2 sensor - you still have one, it's just plugged into my 'fooler' and then that plugs into the car's harness.
here's what they look like (center two items in this pic):
Modified by Black R at 9:15 PM 8/27/2007
mrlegoman
Welding / Fabrication
10
Dec 1, 2006 07:08 PM
si0385.
12
Feb 12, 2006 12:39 AM
Boring
May 20, 2005 08:58 PM
s2kkid
Nov 13, 2004 07:08 PM
