piston rings
I need piston rings. they are pretty cheap, well I mean like 100-150. BUT people are telling me the install is nutsy expensive. and I completely understand why. so my question is, do you knwo a reliable place to do this in southern california, and should I just get like new pistons rods and **** while I am in there so I dont have to pay allot AGAIn or should I get my problem fixed NOW and not worry about pistons and rods and whatever else. also I am planning on turbo, will the pistons and rods and stuff make my compression too high? thanks
Yeah the labor can range from 700-1000 dollars depending on who does it for you. I would recommend you to save up for better parts if you plan on keeping your car for much longer. Get some forged pistons/rods.
hmmm.... my rings are also worn on my 95gsr. Does anyone else know of a place in So Cal that would be good for this type or work (besides the dealer
95integrags-r, if you're gonna boost your gsr in the near future then I would definately spend the extra money on stronger rods and some forged pistons. Depending on how much you wanna boost you could get lower compression pistons. Do it all at once... it would be pointless to spend all that money on labor just to put on new rings and then tear down your motor again later to put in the rods and pistons.
David
)???95integrags-r, if you're gonna boost your gsr in the near future then I would definately spend the extra money on stronger rods and some forged pistons. Depending on how much you wanna boost you could get lower compression pistons. Do it all at once... it would be pointless to spend all that money on labor just to put on new rings and then tear down your motor again later to put in the rods and pistons.
David
doh !!! didn't read the Turbo part
yeah throw in some lower compression pistons while you are at it (if you can) and better rods.
[Modified by Tweakmeister, 5:30 AM 6/15/2002]
i'd sell your engine as is and buy a b18b and build that up.
just my opinion.
just my opinion.
thanks for the help, now does n e one knowe by chance n e where in so cal the will install all that with a good rep??? thanks
well I wasnt planning on selling my engine WHATSOEVER, but, now that people have suggested it, what can I get for it?? and what woul di do with all my mods ie intake headers, im, ect...... Thanks
crxrider07
Mar 14, 2009 10:44 AM
