What caues a warped rotor
Old Aug 24, 2007 | 10:45 AM
The Epidemic's Avatar
Default What caues a warped rotor
My rotors keep warping. this will be the 2nd time i have replaced my rotors this year. I plan on changing the rotor only 2morrow. what can cause this other than speeding and heat..
bad ball joint? i just installed new ball joints(skunk2) last week
Old Aug 24, 2007 | 10:53 AM
B_CRUZ!'s Avatar
Default Re: What caues a warped rotor (The Epidemic)
-don't drive through a puddle
-torque your wheels properly (across like a X pattern) with the right amount of torque
Old Aug 24, 2007 | 10:58 AM
andoxviii's Avatar
I had this issue when I had my old car.
When I first bought the car I bought entirely new rotors, calipers and pads all the way around because they were badly warped and it pulsed the brake pedal.
A week later, they were already warped again and pulsing the pedal.
Same thing happened to my friend, and neither of us could figure it out.
The only similarity I could think of was that both of our cars had previously been in accidents. So I'm thinking it may be possible for the accident to have caused some sort of frame damage that may jeopardize the structural integrity of the vehicle (even the slightest bend that the human eye can't even see without aid)
But this is just a theory of mine, it could be totally wrong. Has your car ever been in an accident?
Old Aug 24, 2007 | 10:59 AM
Default Re: What caues a warped rotor (B*CRUZ)
i know all that.. can paint do that? i did spray my wheels when they were on the car and polly got paint on the rotor
no that i know of
Old Aug 24, 2007 | 11:03 AM
95vxtealhatch's Avatar
Warped rotors can be caused from a shitty manufacturer, or from just exessive high speed braking. Rotor warp when the heat builds up and distorts the metal. It might be possible your a late breaker and your not properly seating in your pads. When you don't seat in brake pads the glaze over, and its possible that with the glazing of the brake pads and some high speed braking that your just wraping the rotors.
Btw Brembo Rotors are great.
Edit: and by shitty manufacturer i mean low grade products, like $10 autozone rotors.
Old Aug 24, 2007 | 11:07 AM
andoxviii's Avatar
Default Re: (95vxtealhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95vxtealhatch &raquo;</TD></TR><TR><TD CLASS="quote">Warped rotors can be caused from a shitty manufacturer, or from just exessive high speed braking. Rotor warp when the heat builds up and distorts the metal. It might be possible your a late breaker and your not properly seating in your pads. When you don't seat in brake pads the glaze over, and its possible that with the glazing of the brake pads and some high speed braking that your just wraping the rotors.
Edit: and by shitty manufacturer i mean low grade products, like $10 autozone rotors.</TD></TR></TABLE>
Here is what the OP said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Epidemic &raquo;</TD></TR><TR><TD CLASS="quote">what can cause this other than speeding and heat.. </TD></TR></TABLE>
Old Aug 24, 2007 | 11:12 AM
Bakeoff's Avatar
I know what warps rotors! They get pissed off from people not SEARCHING!!!
Old Aug 24, 2007 | 11:14 AM
Default Re: (andoxviii)
i do buy cheap rotors!!
Old Aug 24, 2007 | 11:29 AM
ShortyzKustomz's Avatar
The possilibty is also there for bent bracketry for the caliper or the caliper itself either of which could apply more pressure to a certain point on the rotor and cause it to warp in certain circumstances
Old Aug 24, 2007 | 11:45 AM
instructor74's Avatar
Default Re: (ShortyzKustomz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShortyzKustomz &raquo;</TD></TR><TR><TD CLASS="quote">The possibility is also there for bent bracket for the caliper or the caliper itself either of which could apply more pressure to the rotor and cause it to warp in certain circumstances</TD></TR></TABLE>
Seized or gummed up caliper slide pins/caliper piston will cause the caliper not to release all the way causing heat build up and warping the rotors.
Edit: if the slide pins do not move freely and smoothly take the slide pins out degrease them clean the rubber guides with a non petroleum product. (petroleum based cleaner will cause the rubber to swell). Then lube them with a good synthetic caliper slider grease.
Old Aug 24, 2007 | 08:15 PM
Default Re: (The Epidemic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Epidemic &raquo;</TD></TR><TR><TD CLASS="quote">i do buy cheap rotors!!</TD></TR></TABLE>
This could be your problem.
Old Aug 24, 2007 | 08:19 PM
Padawan's Avatar
Darth ModerVader
In most instances, what people perceive as warped rotors are actually uneven pad deposits on the rotor face.
http://www.stoptech.com/tech_i...shtml
Old Aug 24, 2007 | 09:49 PM
ejprimo's Avatar
Default Re: What caues a warped rotor (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">In most instances, what people perceive as warped rotors are actually uneven pad deposits on the rotor face.
keep buying cheap rotors and stop buying cheap pads.
Old Aug 25, 2007 | 01:50 AM
ej_type_R's Avatar
it's probably a combination of weather + your driving habits. do you drive/brake hard, and do you do it often?
I've driven my rides for years and i use cheap pads+rotors. AND i live in the rainy city. yet, i've never had warped rotors.
try driving like a old, old granny for a while and see how it goes...
Old Aug 25, 2007 | 10:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Epidemic &raquo;</TD></TR><TR><TD CLASS="quote">paint do that? i did spray my wheels when they were on the car and polly got paint on the rotor</TD></TR></TABLE> i dont brake hard or late
Old Aug 25, 2007 | 11:02 AM
k0rupt_ed's Avatar
wait rain can affect rotors?
Never knew that..
Old Aug 25, 2007 | 12:30 PM
blkSi's Avatar
Default Re: (k0rupt_ed)
might wanna start looking into your suspension. do all 4 of your rotors warp? check the hubs, maybe the rotors arent seated correctly
Old Aug 25, 2007 | 12:41 PM
tha_badguy's Avatar
you wouldnt happen to have cross-drilled/sloted rotors would you?
Old Aug 25, 2007 | 12:49 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k0rupt_ed &raquo;</TD></TR><TR><TD CLASS="quote">wait rain can affect rotors?
Never knew that..</TD></TR></TABLE>
Water causes a drop in temperature on the surface of the rotor. As your driving, and as its being bombarded by water here and there, its going from hot to cool fast, which causes the metal to expand/contract slightly, which will eventually lead to them being warped out of shape over time.
Old Aug 25, 2007 | 03:47 PM
k0rupt_ed's Avatar
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">
Water causes a drop in temperature on the surface of the rotor. As your driving, and as its being bombarded by water here and there, its going from hot to cool fast, which causes the metal to expand/contract slightly, which will eventually lead to them being warped out of shape over time. </TD></TR></TABLE>
NEver looked at it that way but yeh that makes alot of sence, always good to learn somethin new
Old Aug 25, 2007 | 04:27 PM
Brick Top's Avatar
bingo.
Old Aug 27, 2007 | 02:43 PM
paint
Old Aug 27, 2007 | 03:32 PM
B_CRUZ!'s Avatar
do you paint your wheels while they are still mounted on the car?
Old Sep 3, 2007 | 03:18 AM
Default Re: (B*CRUZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B*CRUZ &raquo;</TD></TR><TR><TD CLASS="quote">do you paint your wheels while they are still mounted on the car?</TD></TR></TABLE> Yes
