Battery Light on
Old Aug 24, 2007 | 09:34 AM
LoveOfMoney's Avatar
Default Battery Light on
sometimes when i drive my battery light turns on by itself. anybody know what the problem is? i got the battery checked and its good. i dont know if it could be the alternator. one day i can drive all day and it wont come on until the next day. it only comes on at random times. anybody know what the problem is? thanks
Old Aug 24, 2007 | 09:36 AM
CRX Toad's Avatar
Default Re: Battery Light on (LoveOfMoney)
Alternator is the first place I would check. And as I always say when you buy one from a parts store have the bench test it before you leave. There are too many of these "new" alternators going out being installed and being bad right out of the box.
Old Aug 24, 2007 | 09:38 AM
turkishEF's Avatar
Default Re: Battery Light on (CRX Toad)
Mine goes on at idle and high RPM from an overcharge.
Old Aug 24, 2007 | 09:50 AM
Hondaisok's Avatar
Check the alternator, belt, connections and all of your ground connections. I had this happen once and it was my ground connection. I run extra grounds from my neg battery post to engine and frame to engine.
Old Aug 24, 2007 | 12:26 PM
jayturboef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">Alternator is the first place I would check. And as I always say when you buy one from a parts store have the bench test it before you leave. There are too many of these "new" alternators going out being installed and being bad right out of the box.</TD></TR></TABLE> x2...every time i go to autozone i see someone getting their new alternator checked and alot of times thay fail the test.. so do what toad said...
i_VTEC
24
Jan 19, 2015 03:32 PM
924doorEG
Sep 21, 2007 06:09 AM
siregcivic
Jun 22, 2006 11:15 PM
Acura EL
Oct 12, 2004 04:01 AM
pane93civhb
Sep 18, 2004 01:39 PM
