Just fabbed up a waterjet machine
Old Aug 23, 2007 | 09:01 PM
HickamHatch's Avatar
Default Just fabbed up a waterjet machine
Here is a 3 head waterjet machine we just built that has a cutting area of 12' by 12'. The watertank is 2 halves that get welded together when it gets there so it would fit on a flatbed. I welded 85% of the parts on this machine. The last couple machines we built were 5 axis heads. typical waterjets we build are 5x10 or 6x12 cutting area. Has a cutting accuracy of .003" square
Old Aug 24, 2007 | 05:30 AM
89crxhf's Avatar
Default Re: Just fabbed up a waterjet machine (HickamHatch)
Thats badass, I wish i had a waterjet of that capacity. what type of pressure does that bad boy put out? does it run an intensifier pump for each head or is it one big one that splits the pressure between the 3?
Old Aug 24, 2007 | 06:18 AM
ebydrc's Avatar
Banned
holy $$$ batman.
Old Aug 24, 2007 | 08:29 AM
Niles's Avatar
I'll give you $50 dollars for it.
Seriously that thing is badass.
Old Aug 24, 2007 | 11:11 AM
Default Re: Just fabbed up a waterjet machine (Niles)
It has a 100hp KMT intinsifier for all 3 heads. Ours at the shop runs at 55,000 psi. I am not sure how much psi they will be cutting with this one.
Old Aug 24, 2007 | 11:36 AM
89crxhf's Avatar
what does a machine that size cost with 3 cutting heads?
Old Aug 24, 2007 | 01:42 PM
Default Re: Just fabbed up a waterjet machine (89crxhf)
customer payed $230,000 for this one. the price varies with the options you get.
Old Aug 27, 2007 | 03:51 PM
Laserjock's Avatar
nice!!!
What motion system is used? I assume using G-Code
encoder feedback?
Old Aug 30, 2007 | 01:30 PM
Default Re: Just fabbed up a waterjet machine (Laserjock)
yes, it is all CNC with G-code. im not sure on the encoder, the electricians deal with all of that stuff. Im always to busy welding the machines together
Old Aug 30, 2007 | 01:34 PM
We have our own software called RE2000. There is a guy that we pay that writes the program for us.
The machine uses ballscrews instead of rack and pinion like a lot of other waterjet companies. Its so much more accurate. Im usually the one that gets the rails dialed in and they have tolerances of +-.003 when straightning them. Most everything is done in house except for when we take them to the surface grinder to have all plains match exactly the same.
Old Aug 30, 2007 | 04:44 PM
92exaccord's Avatar
we have an omax at our facility cuts at 50k psi, very nice piece of equiptment, and we are looking into a six axis waterjet at the moment
myhatchrips
Feb 2, 2004 01:22 PM
