PLEASE HELP ME!!! Brake Conversion Question
Old Aug 23, 2007 | 08:50 PM
kgoner45's Avatar
Default PLEASE HELP ME!!! Brake Conversion Question
I have a 96 civic dx coupe and I did a front and rear disc conversion that came from a 97 integra gsr. I have no abs and Im using the dx proportional valve. The problem is when I drive normally my front brakes drags and the car slows down. It seems like the piston on the caliper is not releasing pressure on time. I checked the caliper and its still good. Is it the proportional valve??? Please someone help because I don't want to expletive up my ****.
Old Aug 23, 2007 | 08:52 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: PLEASE HELP ME!!! Brake Conversion Question (kgoner45)
not your proportioning valve.
Check the caliper slides. The things with the black rubber boot with the bolts going thru. If they are stuck, you will get a drag.
Just pull them out and clean them. you can use vice grips and twist back and forth as you pull them out. they should come out pretty easy using that method. Then clean them with a wire wheel. Re grease...re install...enjoy.
Old Aug 23, 2007 | 08:56 PM
kgoner45's Avatar
Default Re: PLEASE HELP ME!!! Brake Conversion Question (B serious)
Is it the one that is holding the calipers?? the top and bottom 12mm bolts??
Old Aug 23, 2007 | 08:59 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kgoner45 &raquo;</TD></TR><TR><TD CLASS="quote">Is it the one that is holding the calipers?? the top and bottom 12mm bolts??</TD></TR></TABLE>
Yes, the slides that the caliper "clamp" slides on - the two bolts - in the boots.
Also, make sure they're greased. Don't use regular grease b/c it eats away at rubber, use synthetic grease, that's a common problem with caliper sticking.
You don't have that problem with drums .
Old Aug 23, 2007 | 09:01 PM
B serious's Avatar
Default Re: PLEASE HELP ME!!! Brake Conversion Question (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
You don't have that problem with drums .</TD></TR></TABLE>
yeah...but you cant get laid with drums. And he's talking about front brakes. This isnt a 60's VW beetle.
Old Aug 23, 2007 | 11:35 PM
kgoner45's Avatar
let me try to get it fix and give you the result within few days. thanks h-t members.
Old Aug 26, 2007 | 10:18 PM
kgoner45's Avatar
I did the greasing, but it lasted for one day and same problem returned, brakes drags.
Old Aug 27, 2007 | 12:04 PM
polything's Avatar
bump
Old Aug 27, 2007 | 03:34 PM
kgoner45's Avatar
Default Re: (polything)
any other solution??
Old Sep 9, 2007 | 12:45 PM
kgoner45's Avatar
Default Re: (kgoner45)
i looked and found that you have to use 99-00 civic si proportional valve and master cylinder. is that correct?? lmk asap
Old Sep 9, 2007 | 03:49 PM
pauley_lsvtec's Avatar
did you switch the vaccume booster or master cylinder out because i used a master cylinder off of one car and a booster off of another car on mine and it ended up self applying the brakes because the rod in the booster was to long for the new master cylinder.
Old Sep 9, 2007 | 07:36 PM
kgoner45's Avatar
Default Re: (pauley_lsvtec)
rod is find. just once in a while the brakes bind. any one have any problems with this before??
Old Sep 9, 2007 | 07:49 PM
nighttrain33's Avatar
I didn't change my mc or prop valve and mine work fine, but I don't know if the ex's were the same as the dx's.
-Shane
Old Sep 10, 2007 | 08:30 AM
kgoner45's Avatar
Default Re: (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">I didn't change my mc or prop valve and mine work fine, but I don't know if the ex's were the same as the dx's.
-Shane</TD></TR></TABLE>
what's your model dx or lx???
Old Sep 10, 2007 | 08:55 AM
tenedor sports's Avatar
ex civic has a bigger master and bigger front brakes and drums, that is why yours worked out fine, lx dx cx vx, all those models came with **** brakes. I only have the rears on my cx hatch, but once I upgrade the fronts, I believe I will need a prop valve and bigger master....
for more questions about brakes, please pm user "Brake Expert"
Old Sep 10, 2007 | 11:46 AM
kgoner45's Avatar
Default Re: (tenedor sports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tenedor sports &raquo;</TD></TR><TR><TD CLASS="quote">ex civic has a bigger master and bigger front brakes and drums, that is why yours worked out fine, lx dx cx vx, all those models came with **** brakes. I only have the rears on my cx hatch, but once I upgrade the fronts, I believe I will need a prop valve and bigger master....
for more questions about brakes, please pm user "Brake Expert" </TD></TR></TABLE>
so you saying i would need the si/ex mc and prop valve????
kgoner45
Jun 18, 2008 04:26 PM
94HONDAHEAD
Nov 15, 2007 01:43 PM
COLKEOWN
May 28, 2007 10:15 AM
Civic94girl
Suspension & Brakes
May 13, 2005 02:01 PM
