Greddy SP Exhaust Question
Old Aug 23, 2007 | 08:08 PM
melloman's Avatar
Default Greddy SP Exhaust Question
Ok the deal is that I can pick up a Greddy SP exhaust but it's for a 88-91 CRX and I was wondering if I have to mod it in any way to fit my 89 Civic HB. If I do can you please tell me where I would have issues, TIA.
Old Aug 23, 2007 | 08:49 PM
garageEF's Avatar
Default Re: Greddy SP Exhaust Question (melloman)
it must be extended, have a muffler shop do it they are proffesionals.
Old Aug 23, 2007 | 08:57 PM
Crx dude's Avatar
Default Re: Greddy SP Exhaust Question (garageEF)
or just buy the one that fits you car.
Old Aug 23, 2007 | 08:58 PM
melloman's Avatar
Default Re: Greddy SP Exhaust Question (Crx dude)
extended as in the b-pipe?? Or somewhere else??
Old Aug 23, 2007 | 09:04 PM
garageEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melloman &raquo;</TD></TR><TR><TD CLASS="quote">extended as in the b-pipe?? Or somewhere else??</TD></TR></TABLE>
yes, right before the resonator i believe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx dude &raquo;</TD></TR><TR><TD CLASS="quote">or just buy the one that fits you car.</TD></TR></TABLE>
you have no idea how rare this exhaust is, do you?
Old Aug 23, 2007 | 09:09 PM
melloman's Avatar
again stupid question but would a high-flow cat or test pipe fix my problem for the shortness?
Old Aug 23, 2007 | 09:24 PM
mr.speaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melloman &raquo;</TD></TR><TR><TD CLASS="quote">again stupid question but would a high-flow cat or test pipe fix my problem for the shortness?</TD></TR></TABLE>
No,unless you can have it made a custom length for your application.
I personally put a civic exhaust on the crx,what i did was take the civic and crx b-pipes on the ground next to each other,then from there its pretty self explanitory
Old Aug 24, 2007 | 12:20 AM
crx_si-r's Avatar
Default Re: Greddy SP Exhaust Question (mr.speaker)
ok, i have a greddy sp1 exhaust on my crx. originally i had it on my hatch then i took it off and it was then cut and welded at the pipe where the resonator is, i think it was shortened by 4 inches. and then it was also cut about another 3 inches at the pipe that wraps around the fuel tank. so urs might need to added in those areas to fit ur hatch.
Old Aug 24, 2007 | 12:11 PM
melloman's Avatar
Default Re: Greddy SP Exhaust Question (crx_si-r)
Thanks alot guys exactly what i needed to know. Debating still if I should get it and then take it to a shop, or dish out $600CDN for a brand new SP2 which is made for my HB. Again thanks for the info
-mello
Old Aug 24, 2007 | 12:43 PM
import2nr88's Avatar
Where the length has to be added is just to the rear of the resonator located on the B-pipe. It will be close to 6 or 7 inches. If you add it to the cat then the mounts where it connects to the hangers would not line up.
Old Aug 24, 2007 | 02:57 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melloman &raquo;</TD></TR><TR><TD CLASS="quote">Thanks alot guys exactly what i needed to know. Debating still if I should get it and then take it to a shop, or dish out $600CDN for a brand new SP2 which is made for my HB. Again thanks for the info
-mello</TD></TR></TABLE>
I say sell your CRX one and buy the correct one for your HB. By the time you paid somebody to cut and re weld yours it would cost maybe just a little less than the HB version that bolts right up and still looks pretty w/o any hacked up welds . It depends on the condition of your CRX exhaust but if it's in good enough condition you should be able to sell it for a decent amount to help cover the HB one. I have the Sp2 on my REX (and love it) and I just hate to think about cutting it up and disrupting the perfect flow it already has
Old Aug 24, 2007 | 03:18 PM
wickedEFguy's Avatar
The rear muffler and B pipe should be eactly the same...Although the hangers on the B pipe need to be relocated. You'll probably have to extend it a few inches as well.
That's what I had to do with the Greddy MX exhaust I got that was on a hatch which is now on my CRX
Old Aug 24, 2007 | 04:23 PM
Crx dude's Avatar
you have no idea how rare this exhaust is, do you? [/QUOTE]
Ya its a good exhuast thats why I say dont cut it to pieces. Like someone already said just sell it buy one that fits.
Old Aug 24, 2007 | 05:05 PM
burnout8488's Avatar
Default Re: Greddy SP Exhaust Question (VtecSyndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">I say sell your CRX one and buy the correct one for your HB. By the time you paid somebody to cut and re weld yours it would cost maybe just a little less than the HB version that bolts right up and still looks pretty w/o any hacked up welds </TD></TR></TABLE>
I agree about the hacked up welds part. Some shops do a crappy job and it will make it look horrible. However, it'll be under the car, nobody will know. It won't affect power either.
However, it should only cost about $20 bucks at any reputable muffler shop to extend it. Not nearly as much as you implied!
If it was my car: I'd get the correct one.
Old Aug 24, 2007 | 06:35 PM
fireant's Avatar
Default Re: Greddy SP Exhaust Question (burnout8488)
SP2 wont rust.
McFlurry
Jul 6, 2006 08:49 AM
whitehf
Jun 29, 2006 11:26 PM
ricetoniceeg
Oct 31, 2004 11:40 AM
piatl7il77
Aug 9, 2004 04:47 PM
lastpunkinline
Mar 25, 2004 05:29 PM
