Welding alum oil pan some questions in here regaurding tig
OK question about welding 1/8" alum pan
Whats the best technique to keep it from not warping. Im gonna bolt it to the block when im welding it should i do it in 1" sections and flip from one side to side.
Im welding a pan flange one to a moroso pan
I just did one. Preheat it with a small torch from home depot.
It only takes a few minutes. Do this after it is bolted down, then weld.
Just make sure to move around as much as possible and backstep.
While cleaning it I discovered a very quick way to preheat.
I was preheating and I hit a little puddle of brake cleaner...
The I remebered highschool hairspay antics, VOILA!
Done carefully, it takes only seconds to get a good heat spread.
Please don't burn anything down.
OK cool. Talked to a budy mine said to acetone it to death get as much of the old oil out of the old flange then tac it. then heat it with a propane torche and do small sections.
Ok ill post some pics up tomorrow
thanks.
Another note i usualy run my argon at 15psi feel sometimes i get better welds out???
thanks.
My95SlvrBlt
40
Jan 19, 2007 07:33 AM
